| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Here on offer is a fully stuffed DCB1.
It is on a Home Brew PCB. All components have been matched and everything works OK. There is a small isue with the PCB that is causing one channel (either) to occasionally distort. This is almost certainly down to a whisker of copper trace causing an intermittent short. 2SK170BLs were matched within 0.01mA of each other and the LEDs have been chosen to give the required voltages. Ideal if you are looking for the components for a SALAS / DIYSTORE Hypnotise board or alternatively put it under a microscope and see if you can spot the short. £30.00 plus P&P (Its not heavy so wont cost much to post) Photo 1 shows the 2SK170BLs missing, I've only included this photo as it is a better photo of the board. Please note that it is only the board (stuffed) that will be supplied. Last edited by KatieandDad; 25th February 2012 at 12:11 PM. |
#2 |
I'm going to put a hold on this one too. BuzzForb has convinced me try again and get it working.
At some stage either the B1 or the DCB1 will become available as I don't need both. |
| F/S Fully stuffed and working B1 pcb | Marra | Swap Meet | 1 | 22nd February 2012 10:18 AM |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| FS Pass Labs Pearl fully stuffed and MC pre. | steenoe | Swap Meet | 6 | 17th June 2008 12:43 PM |
| FS: Mauro MY_Ref Rev.A fully stuffed board | DcibeL | Swap Meet | 3 | 6th October 2006 11:59 PM |
| Aelph Main Boards Fully Stuffed | Coulomb | Swap Meet | 21 | 13th June 2005 01:35 PM |
