I've got two Betsy prototypes that need homes. The Betsy is my open baffle specific 8" fullrange. I switched cones this fall, and these were two samples. The first cone was a little heavy, so the speaker is about a half decibel less sensitive and has a slightly higher Qts. The second speaker is in every way identical to the current production Betsy, it just isn't labeled as such, doesn't have the same box, and was made a little earlier. You could take the 1st one for an old console or a center channel. The second one would pair perfectly with current production. Or, you could take them as a slightly mis-matched pair for non-critical applications (garage/bench). The cones are both black, and cosmetically identical to new production Betsys (and BetsyKs, from the front).
I'd like $10 each to cover Priority shipping and paypal fees in the CONUS. I'd rather not send them overseas unless you combine them with a purchase.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Paul
