I have an output transformer in appearently excellent conditiom.
It comes from an 80'2 era pro SS amp which was rated 100W. The only identification is the label P-100451, probably thje amp mfg's part number.
However befor removing it I labled the leads.
Primary has three: one from each of the output devices and the third I presume to be common. Weight seems to be 5-6 lbs
(2 kilos)
Secondary has 6ix labled 70V, 25V, 16-ohm, , 8-ohm, 4-ohm and COM.
US35.00 plus shipping (note the weight).
(2 kilos)
