Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 22nd January 2012, 04:51 PM   #1
Default 4x 18" woofers and other stuff, free for local pickup.
My first attempts in building a baffleless speaker: 2 AL1800 (18") woofers per side up to 300Hz, and a 8" FR speaker from 300Hz onwards. Haven't performed any measurements on it, and there was surely still room for improvement, but not bad at all for a start.
I am keeping the Fostex FR drivers, but you can have the MDF baffles to build in another set of 8" FR drivers.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 22nd January 2012, 04:54 PM   #2
Specs of the woofers:
Nominal diameter 450 mm
Rated impedance 8 Ohms
Power capacity 200 W
Sensitivity 98 dB
Frequency range 25 - 3,000 Hz
Thiele-Small-Parameter
FS 29,9469 Hz
Re 7,2000 Ohm
Qms 8,3143
Qes 0,6767
Qts 0,6258
Vas 518,4930 l
No (Ref efficency) 1,9898 %
Sd 0,1195 sqm
Motor Impedance Parameter
Levc (Induc at 1 kHz) 1,3702 mH
Levc (Induc at 20 kHz) 0,6482 mH
Krm (Resistance Cons) 9,2922 mOhm
Kxm (Reactance Cons) 12,1807 mH
Rem (Res at 1 kHz) 4,3991 Ohm
Rem (Res at 20 kHz) 36,2865 Ohm
Erm (Resist. Expont) 0,7043
Exm (React Expont) 0,7502
If you are interested you can also have the 'enclosure' for free... I will only keep the Fostex driver.
Old 22nd January 2012, 05:04 PM   #3
Send a message via Skype™ to Rullknufs
Dang, should've had those woofers for my econowave project. Too bad I'm not your neigbour
Old 22nd January 2012, 05:10 PM   #4
Boden is offline Boden  Netherlands
Erik, where do you live?
Eelco
Old 22nd January 2012, 05:13 PM   #5
Hi Eelco,
Thanks for reminding me about the location! I live in Eindhoven, smartest region in the world
https://www.intelligentcommunity.org...2011&refno=634
Best regards, Erik
Old 22nd January 2012, 05:17 PM   #6
Hello Erik,
If indeed for free, I am interested in your 4 woofers. I am contemplating about finding time to pick them up.
Eelco
Old 22nd January 2012, 06:16 PM   #7
I can arrange a courier to pick your 4 woofers in case Boden no longer wants them!
Old 22nd January 2012, 06:17 PM   #8
I am interested!
Eelco
Old 22nd January 2012, 06:19 PM   #9
Erik, you have mail.
Eelco
Old 28th January 2012, 10:22 AM   #10
Erik de Best,
Where art thou?
Kind Regards,
Eelco
Snell Acoustic Type A - free, local pickup Seattle tg3 Swap Meet 8 28th January 2009 06:13 AM
Two power transformers - free for local pickup (Seattle, WA) owdi Swap Meet 0 12th January 2008 07:40 PM
Free for local pickup..Quadrature DSP5a rosewood cabinets only JandG Swap Meet 0 18th November 2007 04:40 PM
For Free (local pickup only) : Sonotube enclosure for 12" driver zobsky Swap Meet 6 9th May 2007 06:19 PM
Free Plate Amplifier for local pickup in Seattle motherone Swap Meet 6 31st January 2006 01:46 AM
Page generated in 0.12162 seconds (80.27% PHP - 19.73% MySQL) with 11 queries
