Hello good people
I have taken a u-turn in my buildingplans, and I no longer need my B1. It is assembled and mounted to a GX283 chassis, it has 0.1% and 1% resistors of no special "audiophile" brand, and they are mounted per instruction. It has a Velleman regulator and a Noratel transformer. It sports Mundorf and Panasonic caps and dual mono PEC pots (not mounted). I also have a power entry module, which I couldn't figure out how to use, and a 2 pole selector switch. The cabinet is Modu Galaxxy Maggiorato GX283, BUT, I have drilled the front and back panel, and not a very good drilling. You will need new ones.
Ships from Norway. Open for bids.
Kenneth
Kenneth
