I have bunch of trafos that are just taking space in my closet.
1. Trafo that was pulled from Pioneer SX-750 receiver. Good for somebody that needs an exact replacement. May work with other receivers as my SX-838 also uses the same trafo.
2. Brand new small transformer (1"x1") made by NanHai NRE Electronics Manufacturing Co. Ltd. Part # ECO-228A-37.
Pri: 120V AC 60Hz F2 1A 115deg C
Sec: 10VAC/0.1A
Date code: 0609
3. Brand new CT toroidal transformer made by Eaglerse Electric & Electronic Co, Ltd. Part numbers: 417D6-37, H0200-0845. Approximately 4" in diameter.
Pri: 110V 60Hz, A5-3A-F 135deg C, 250V
Sec: 24V-0-24V, 5.5V, 16.5V, 16V-0-16V
Make me an offer if you are interested. Shipping would be from ZIP 07605 (Leonia, NJ). Most likely USPS flat rate would work the best for the heavier transformers.
Thanks for looking.
Sec: 10VAC/0.1A
Date code: 0609
Thanks for looking.
