Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Lambda TD15X Woofers with APOLLO Option 0 pr
Old 8th December 2011, 04:50 PM   #1
cm7 is offline cm7  United States
Default FS: Lambda TD15X Woofers with APOLLO Option $490 pr
FS: Lambda TD15X Woofers with APOLLO Option Pair
One new in box one used for testing and is dusty but otherwise works and looks great. They both are rare Apollo versions with extra heatsinking for lower thermal compression.
TD15X - 8ohm
Fs: 23.2.0Hz
Qms:3.82
Vas: 467L
Cms: .45mm/N
Mms: 105g
Rms: 4kg/s
Xmax: 14mm
Sd: 855
Qes: .31
Re: 5.6ohm
Le: .3mH
Z: 8ohm
Bl: 16.7Tm
Pe(cont): 500W
Qts: .28
1W SPL: 94.8dB
$490 Pair plus shipping from 78750 (US only)
Paypal add 3%
They weigh about 25lbs each. I'll ship in one box if I can, but it might be 2 boxes.
Old 8th December 2011, 04:55 PM   #2
Default Pictures
Pictures of TD15X Apollo Woofers
Old 17th February 2012, 03:37 PM   #3
sold
FS: Lambda TD15X Woofers with APOLLO Option 0 prHide this!Advertise here!
FS: Lambda TD12M Woofers $295(pair) cm7 Swap Meet 7 25th November 2011 08:18 PM
FS - New Lambda Acoustics TD15X Apollo drivers - 8 ohm SMathews Swap Meet 5 20th October 2006 02:44 PM
FS: pair of new Lambda TD-15S sealed box woofers taloyd Swap Meet 2 5th June 2006 03:45 AM
FS: Lambda Acoustics TD12S (faraday) woofers pkpickard Swap Meet 5 18th December 2004 10:56 PM
Lambda TD15X woofers thylantyr Multi-Way 3 10th September 2002 08:45 AM
Copyright ©1999-2017 diyAudio
