FS(UK) - Valve Amp KT-88 based SET
For sale is my KT-88 based SET - DIY made. This provide a 7W x 2 output. Working well and used sparingly. Needs to be picked up from bristol due to weight and delicate parts. Please send offers by PM. The parts would cost around 400 GBP.
Has the following components. Schematic will be provided
KT-88 x 2 new Svetlana KT88
D3a x 2 siemens
5U4G x 1
374BX power transformer
UBT2 x 2 (5k output transformer)
CHOKE x 1 193j 10H, 200ma
100Uf x 2 (450) mundorf
20uF x 1 (600v) mundorf
CCS IXYS10M90S x 2 with heatsink
ALPS Pot
Bump - FS in UK, KT-88 based SET
Please check below. Please send me a PM with a price in mind. Negotiable.
Vinod
D3a x 2 siemens
5U4G x 1
ALPS Pot
Details and Pics
Iam adding 2 pics. The case is a steel Hammond make.
The transformer 374BX is again Hammond and can be looked up. Essentially
Primary - can be wired for both 120/240 V
Main Secondaries given below.
- 750V CT (175ma)
- 5V CT (3A)
- 6.3V CT (6A)
The choke 193J is 10H, 200mA.
The OPTs are UBT2 - US made. 5K primary to 4/8/16 Ohms. 110ma max primary current. Max output = 13 W
The power output of the amp should be around 5 to 7 W x 2 channels.
The coupling caps are Audiocap, filter caps are Mundorf and other caps from Nichicon. There is a CCS circuit on the anode of the D3a.
Vinod
