Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 21st September 2011, 07:24 AM   #1
Cool FS: 300Hz 2" throat Edgarhorns and LE5-2's
Contact me for photos and more info.
The horns have the less common detachable 2" throat extensions, enabling you to upgrade/swap between a high quality cone driver like the LE5-2 (top choice) or a 1", 1 3/8" or 2" compression driver. If you want to use a compression driver smaller than 2", metal conical adapters are always available on ebay.
This is the same horn used in the Edgarhorn Slimline. If you use it with the alnico LE5-2, be prepared for a very detailed and relaxed presentation from 400-10KHz at 105db/w.
According to Dr. Edgar, the more controlled directivity of his rectangular tractrix is an advantage over the less controlled directivity of his round tractrix in smaller rooms and nearfield listening, and sounds almost identical to his round tractrix horns overall.
"BEST" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? bear Multi-Way 163 26th November 2011 12:45 PM
FS: FOSTER Horn Tweeters (long throat) & ~3" Midranges speaker Swap Meet 2 16th August 2010 01:27 PM
FS - Neocd2 & Morel DMS37, JBL LE5-2's, Fostex Guiness Swap Meet 0 19th February 2009 12:07 AM
FS: Edgarhorn 300hz horns, JBL LE5-2's, and Lambda TD15M & crossover parts Rescue Toaster Swap Meet 2 3rd January 2007 04:34 PM
FS 350hz edgarhorns rich christie Swap Meet 4 9th December 2005 06:28 PM
Page generated in 0.12939 seconds (34.96% PHP - 65.04% MySQL) with 10 queries
