Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 19th September 2011, 05:09 PM   #1
cobo is offline cobo  Scotland
Default FS: Nap140(Ncc200 clone) boards, upgraded components. Fitted to heatsink. Plus extras
FS: Nap140(Ncc200 clone) boards, upgraded components. Fitted to heatsink. Plus extras.
Original transistors. Everything else replaced.
  • Nichicon KZ caps added bypassed with Wima 0.1uf.
  • Vishay 0.1% 25 ppm precision resistors in signal path.
  • Ceramics replaced with LCR Polystyrene and Silver Mica
  • Oscons and 47uF wet tantalum fitted.
  • Power resistors changed for better quality metal film.
  • Emmiter resistors changed to 7w wire wound. Fitted under board.
  • 15ohm resistor and inductor fitted at output.
  • Seperate 0v point added for zoble.
Have been using these as my main amp since December 2010. Upgrading to Hackernap so thought someone else could get the use of them. I used them with a 2x 0 - 27v transformer with dual rectifiers. Obviously the will need to be re-biased for whatever your set up will be. I'll include as much paperwork and schematics as I can from original build.
I'll also include the following.
  • DIYHiFi.net speaker protection board, plus the 24v transformer for it.
  • Hand etched power supply boards as pictured above. (Minus the large smoothing caps and PCB tabs which have been removed for use on another amp.)
  • 4x35Amp 600v Motorola bridge rectifiers.
  • Bullet connectors for Nap140
  • 4 spare 0r22 emmiter resistors.
I'm drowning in electronics here. So time for a clearout.
I reckon £55 delivered in the UK is a fair price for the built boards and extras. Paypal accepted. PM me if you're interested.
Col.
Old 20th September 2011, 11:39 AM   #2
Reduced to £45.
Col.
Old 20th September 2011, 11:33 PM   #3
Now Sold.
NAP140/NCC200 Clone with PSU Neutrality Solid State 30 13th February 2013 01:20 PM
FS: ezDAC and ezDUAL boards unused + select components grimberg Swap Meet 1 17th June 2011 06:02 PM
FS: Angela MosFet driver boards with components wimdehaan Swap Meet 0 4th August 2010 09:09 AM
FS: One set of F1 clone amp boards (2 channels) cfcubed Swap Meet 8 25th May 2009 12:41 PM
Page generated in 0.13247 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
