diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: 1500VA balanced toroid isolation transformer (http://www.diyaudio.com/forums/swap-meet/195847-fs-1500va-balanced-toroid-isolation-transformer.html)
JLH 3rd September 2011 12:45 AM
2 Attachment(s)
Here we have a balanced (60Vac + 60Vac) power transformer from Toroid of Maryland. This is a very high quality medical grade transformer. This will clean up your mains line and give your audio system new silence and clarity. I use them on all my equipment. This is an extra one (I have two extra ones actually) that I don't need. It will run pretty much a entire system up to 17.5 Amps at 120Vac. See the below link for the data sheet. Also see the links below the data sheet to read about some of the benefits of balanced power for your audio equipment. This is one of the best upgrades you can make to your system. Brand new these transformers are $350 a piece. I'm offering these for less than half the original price of $150 plus shipping. These are 26 pounds a piece, so keep shipping in mind. Local pick up is welcomed.
http://www.toroid.com/standard_trans...T1500X_SPM.pdf
Feature Article
HTGuide Forum - DIY Balanced Power project
JLH 7th September 2011 10:28 AM
This is still available. If you need application help, I can answer your questions.
badman 4th October 2011 11:47 PM
Would you split shipping to 92780? If so, I just need a total and you'll get your moolah!
JLH 6th October 2011 02:06 PM
I should have a shipping cost by the weekend.
Rgs, JLH
thatoneguy 29th November 2011 05:01 AM
Are these still available?
Resources saved on this page: MySQL 18.75%
