Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 16th August 2011, 06:20 PM   #1
aziltz is offline aziltz  United States
Default DIY Op Amp Buffer Boards
I had some PCBs made for a Op Amp based multi-buffer circuit. It was designed with guitar and bass in mind, but it could be useful for other projects as well, volume pedals, piezo buffers, splitters, etc...
Here's where it started
They are nominally $5 each. More info/buy here. The project documents are mostly done, but I'll be updating them when I have time.
I'd be happy to answer any questions here or through PM.
Old 22nd August 2011, 04:46 PM   #2
Vacation in Portland. Next Batch goes out August 27th with the finalized version of the build documents.
Old 26th August 2011, 01:29 PM   #3
Little hiccup from Irene. Will ship new orders on Monday.
Old 26th August 2011, 05:17 PM   #4
jtjy is offline jtjy  Singapore
Assuming my amp doest not have a pre out, can i buffer the input for 2 output? 1 for amp and 1 to active sub
Old 26th August 2011, 05:44 PM   #5
yes, that would be the same as the splitter application I've listed. I don't yet know if it will drive an isolation transformer.
Old 26th August 2011, 05:49 PM   #6
wad do u mean by isolation transformer? also which config should i use and how many boards do i require for the above application? sorry i just started in diying audio
Old 26th August 2011, 05:53 PM   #7
you want what I've described as the "splitter" in the document, http://www.coldcrafteffects.net/PCB_...uild%20Doc.pdf
I'm working on Wiring Diagrams and fleshing out the info in the document, but I might lose power this weekend.
An isolation transformer would allow you to disconnect the grounds of the two outputs. Some applications might cause excessive hum without it, but I haven't had a chance to test whether it can drive a small 1:1 transformer yet, though I suspect it will.
Old 26th August 2011, 05:54 PM   #8
alright. will wait for your updates. Will be getting from you when stock arrives.
Old 26th August 2011, 06:00 PM   #9
stock is already here in hand. I'm just putting off shipping orders until monday because of the storm. I am definitely going to be losing power this weekend.
Old 30th August 2011, 04:18 AM   #10
I lost power over the weekend. thankfully nothing else was lost. I'll be shipping out starting tuesday.
Class A Buffer Op amp ttan98 Chip Amps 8 12th August 2011 06:50 PM
op-amp + op-amp buffer combinations eccdbb Chip Amps 2 22nd July 2011 04:13 AM
Preout / buffer op-amp yakideo Chip Amps 5 9th March 2011 08:33 AM
Op-amp Buffer johnferrier Solid State 30 28th October 2003 05:38 PM
Page generated in 0.12161 seconds (78.51% PHP - 21.49% MySQL) with 10 queries
