Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 1st August 2011, 08:21 PM   #1
paul.42 is offline paul.42  United Kingdom
Default wanted transformer for sony ta-f444es mk2
wanted transformer for sony ta-f444es mk2 long shot i know.thanks for looking.
Old 1st August 2011, 11:40 PM   #2
ByronInLawrence's Avatar
Location: Lawrence, a nice little college town in Kansas
I noticed that a few days ago someone sent you a link to the service manual. Did that tell you the transformer's voltage and current rating? You don't need an exact replacement. You just need a transformer which matches the voltage, and has equal or higher power rating. If you decide to replace with a different transformer, but don't know how to hook up a transformer, you can ask for help in any of the Amplifier forums.
Old 2nd August 2011, 01:31 AM   #3
prairiemystic's Avatar
I've seen Sony transformers for sale on eBay, if you know the Sony part number. They're usually Bando make.
Old 2nd August 2011, 04:57 PM   #4
Default sony ta-f444es
you have pm
Old 5th August 2011, 04:20 AM   #5
Default check the primary thermal fuse
paul.42 unless the xfmr is obviously toast,
I have a Bando pwr xfmr from a salvaged Pioneer home theatre receiver. I removed the small AC line pcb (2 pins) and found underneath it, the bobbin actually has three pins - two of which connect to a primary thermal fuse. I can see the fuse lead-in but it's buried in the bobbin and varnish. You can use an ohmmeter to check the fuse.
Another thing I found common is cold solder joints on the mag wire/bobbin connections, so look for that.
Old 5th August 2011, 12:56 PM   #6
Hello
I have several SS power transformer, mostly from home theater amplifier.
Like JVC,Yamaha, etc holding dust.
You have to know the voltage rating min. to get help.
I have a Sony GA7ES home theater receiver works but the face plate messed up I purchase $50.
I'm willing to take the transformer out for the same price.
Again you have to found out the V & VA rating...
Greetings gabor
sony ta-f444es mk2 schematics paul.42 Swap Meet 4 1st September 2011 04:45 PM
Wanted Sony BX269A IC / TA-8650 zedrider Parts 0 21st February 2009 06:40 AM
Sony TA-N1 and TA-NR1, how do they sound? lumanauw Solid State 0 28th November 2006 01:51 AM
Wanted: KSA100 mk2 Jozua Swap Meet 1 12th May 2005 10:58 AM
FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp MJR Swap Meet 1 6th December 2003 07:55 PM
Page generated in 0.07666 seconds (85.24% PHP - 14.76% MySQL) with 10 queries
