| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hallo!!
I am trying to clone a EAR 834. The reason that I choose this one is I like everything this amp gives, but it high frequencies. I need "A LOT OF CAPACITORS" !! Especially, 8 pieces of high voltage caps, 400 mf/250V. Any offer would be apprecaited. cchen
#2 |
Hello Contaxchen,
I have many 680UF 250 Volt Panasonic TSU capacitors, new never used. let me know if you are interested. Thanks KevinLee
#3 | |
#4 | |
diyAudio Senior Member
Frank |
#5 | |
Swapping electros is changing the flavour of the turd. |
#6 | |
You assume low current draw from an integrated amp? I'm no big fan of electros either but I can assure you that in a well thought out design you won't hear them at all. Don't even need chokes for that... Either way, without having had a glance at the circuit there isn't much to argue about. Cheers,
Frank |
#7 |
It's a couple of 12AX7 and 12AU7.
ax-ax-au(cf) with inverting feedback/RIAA to the grid of the second ax. 20mA/ch max. PSU is a doubler and the heaters are DC, series strung. |
#9 | |
Cheers |
#10 |
I have stock of some 470uf 450V snap-in caps at $3.00ea
Steve @ Apex Jr |
| Help needed ! Inter M R300 schematics needed ! | alexclaire | Solid State | 30 | 9th September 2009 06:14 AM |
| Help needed to identify these components | Ruach | Digital Source | 1 | 22nd July 2007 08:24 AM |
| DIY components? | MarkR | Car Audio | 1 | 27th May 2006 06:57 PM |
| Components needed for this kinda project? | blake_mooney | Multi-Way | 4 | 6th May 2006 02:10 AM |
| Which components | thirunash | Car Audio | 0 | 4th June 2005 07:40 AM |
