Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Pair Hammond 125ESE single ended output transformers
Old 24th August 2003, 12:59 AM   #1
Saurav is offline Saurav
Default FS: Pair Hammond 125ESE single ended output transformers
I have a pair of Hammond 125ESE SE OPTs for sale. I built my 2A3 amp with these, and liked the amp enough to decide to upgrade to better output transformers. The 125ESEs have developed a reputation for being excellent 'beginner' transformers. They're cheap, can be configured for a range of impedances, and sound excellent for the price. You can search through the tube forum here on diyAudio for more information, and here's a test/review that Steve Bench performed on these transformers:
http://users.starpower.net/je2a3/125ESE.htm
The transformers have been in use for a couple of months, so they're pretty new. All the leads are at their original lengths (minus a few mm where I had to cut them off the soldered ends). I didn't trim any of the unused leads, so you should be able to use this at whatever impedance combination you want. I've spray-painted the transformers a glossy black (flat black + glossy clearcoat). The paint job isn't perfect, but you can easily re-paint them to suit the 'decor' of your amp. These are the perfect output transformers for someone starting out on their first tube amp, or for a cheap/second project.
Specs (taken from the Angela website):
15 Audio Watts, 80mADC, primary tapped at 10K/5K/2.5K, secondaries 4/8/16/32 ohms. Weighs 3.15 pounds, measures approx. 3.5"X2"X3" tall, mounting tabs extend .5" from the bottom edge of the frame, mounts to chassis with two screws, upright mounting open frame constuction.
I paid $62 for these, asking for $40 + actual shipping charges.
Old 24th August 2003, 01:02 AM   #2
Second post for second image (since I'm feeling too lazy to upload these to my web space and link them in):
Old 28th August 2003, 05:16 PM   #3
OK, how about $30 + S/H?
Old 28th August 2003, 07:44 PM   #4
Sold.
FS: Pair Hammond 125ESE single ended output transformersHide this!Advertise here!
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 03:05 AM
Pair Hammond 1628SEA single ended transformers for $175 SEPlover Swap Meet 0 21st May 2009 02:32 PM
Pair Hammond 1628SEA single ended transformers for $199 SEPlover Swap Meet 0 22nd March 2009 01:06 AM
Black Art Single Ended Output Transformers DVDHack Tubes / Valves 2 11th January 2004 05:02 AM
Using PP output transformers for single ended amp SHiFTY Tubes / Valves 4 26th August 2002 08:18 PM
Copyright ©1999-2017 diyAudio
