Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 24th July 2011, 05:03 AM   #1
Mr Teal is offline Mr Teal  Canada
Default FS: Caps, Transformers, HS with output stage
Well, after getting married, starting and completing university and having a kid I'm slowly coming to the realization that many of the projects I have on the shelf are probably never going to get finished. Most have been sitting unused for 6 years. I'm looking to sell off some of the parts I've acquired over the years and make some of the cash back that I spent on them.
First up, 4x10mF 100V 85C Mallory Caps. They're the smaller ones, 2.5" wide by 4.5" high to the top of the lugs. $40+shipping
Next, 4 x 22mF 100V 105C Cornell Dubilier caps. They have some dents in them, but they charge to rated voltage with no issues. $20+shipping
The caps were all bought off Coulomb on the forum here.
Big Capacitors for sale
If you want all of the caps, I'd do $50+shipping
Next, two Powertronix 208V/120V 1.9kVA toroidal transformers. These things are beasts, you obviously have to downrate them if you run at lower voltages, but when I hooked them up for testing they output +/- 85-90VDC after filtering. The transformers are 7.5" in diameter and 3" high, the two weigh about 60lbs together, I'm asking $30 + shipping.
The last items are two black anodized heatsinks, about 12" x 5 7/8". The fins are 3", spaced about 3/8" apart with a 1/8" baseplate. Attached to the heatsink is the output stage of a monster Elliott Sound Products P68A-based amp. The first one has 5xMJL4281A and 5 MJL4302A BJTs equally spaced under an steel retainer, along with some output resistors. The transistors are all fine as far as I know, but it's not fully wired. It also has a gold back for some reason, though the rest is black. The second is functional and works fine, it also has 5xMJL4281A and 5 MJL4302A along with emitter resistors, zobel network and 4x1000uF 100V 105C caps per rail. I included the schematic of the output stage. If you want, I'll even throw in the P68A input stages that I was working on tuning before life happened. I know the transistors and circuit's probably aren't work much, so if you want consider them a bonus, if not I can strip them off, save the BJTs and toss the rest to save weight. It would pain my heart to do that to the nice one though, it took a lot of work to make it that pretty.
Looking for $30 for the heatsinks + shipping, or $50 for the both of them.
Please let me know if you have any questions.
Thanks,
Dave
Old 24th July 2011, 05:03 AM   #2
Here's the schematic, if anyone's interested.
Old 24th July 2011, 05:10 AM   #3
pm sent
Old 24th July 2011, 02:58 PM   #4
A couple clarifications. That should have been $30 each + shipping for the heatsinks or $50 for both, and there's also 9 of each output devices on one heatsink (18 total) as per the schematic, not 5 as mentioned.
Old 24th July 2011, 09:07 PM   #5
The Mallory caps are spoken for.
Old 27th July 2011, 06:42 AM   #6
Hello
Shipping for the two transformers to Toronto M6L 2N5 postal code.
I prefer surface mail. Ha ha ha.. 60LB via air mail I think not affordable.
These are not center taped, to use it need both.
Greetings gabor
Old 27th July 2011, 04:59 PM   #7
PM sent, gabor.
Old 28th July 2011, 11:38 AM   #8
Mayank is offline Mayank  United States
Mayank's Avatar
PM sent.
Rgds, Mayank
Old 28th July 2011, 04:11 PM   #9
Well, I haven't heard from the person who was interested in the Mallory caps for 4 days, so I'll put them back out there. Also, the Cornell Dublilier 22mF caps are 85C rated as shown in the picture, not 105C. My mistake, sorry.
Old 8th August 2011, 03:27 AM   #10
I still have all this stuff, so if anyone is interested send me an offer.
wideband transformers suggestion for output stage for dac or cd players? jfrago Digital Line Level 14 3rd February 2009 09:58 AM
N.P. Caps for Osc Output stage Zero Cool Everything Else 12 15th June 2008 07:43 PM
Newb Questions RE: HS caps & B+ Bias Renron Tubes / Valves 12 20th December 2007 06:45 AM
Oscons as decoupling caps in output stage Ruach Digital Source 6 24th August 2005 04:31 PM
AD825 output stage:What bypass caps? filholder Digital Source 3 16th April 2005 06:15 PM
Page generated in 0.13627 seconds (73.86% PHP - 26.14% MySQL) with 11 queries
