Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 19th June 2011, 02:51 PM   #1
Default WTB: reflex tube - anybody buying from PE?
I need a small diameter tube, but I'm unable to find locally something appropriate, only some metal ones, that I don't want because they can vibrate.
I found the tube I need by Parts-Express: Port Tube 1" ID x 4" L Flared
The problem is that PE doesn't ship to Italy such a small order, so I'm asking someone who already needs material from PE to include also the tube and then ship it to me. I expect a small package to Italy to cost in the order of 5$.
Payment by paypal.
Write directly to ralf_loi at it . ibm . com
Old 21st June 2011, 12:05 AM   #2
garyroach's Avatar
Do You just need one? I have a 1 1/2" X 4" long flaired port from PE in my junk box. If you can use it you can have it free. Just pay me for shipping.
Old 21st June 2011, 08:55 AM   #3
Thank you for your kind offer, but I have severe constraint in space on the baffle, and I don't want to put it on the rear because it is for near field. The 1" is the only one that fits.
And yes, I need only one.
Thanks again,
Ralf
Old 21st June 2011, 04:00 PM   #4
If you only need a small diameter tube for a reflex box port, I suggest that you use a cardboard mailing tube. Look for a tube that is smooth inside. These are easy to find in the USA, at any store that sells office supplies and they are very inexpensive. It will be more than adequate for the job, since the small diameter will make it stiff enough. You can easily glue it in to the cabinet wall, and then chamfer the hole (flare it where it opens to the outside) if you would like.
-Charlie
Old 21st June 2011, 06:45 PM   #5
There is a large selection of thin wall PVC-tubing you can get at your local DIY supply. It is actually quite easy to make flares on these, using a little heat. First find an object you can use as a punch to make the flare. White wine bottles work good, but might be a tad too large for 1" pipe. What you do is wrap some masking tape around the pipe where you want the flare to end. Heat it up the end to about 120-130 degrees C with a heat gun at middle setting. Then push on top of the bottle or other object.
P.S.
When I lived in the US I noted that the white PVC pipes being used for drainage in plumbing are way thicker than the grey ones used in Europe. Don't think it will work with thick walled pipe.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
Old 22nd June 2011, 10:41 AM   #6
In the spirit of DIY I appreciate the suggestions. However I would like to use a tube with a flange, and for this reason I'm asking for the PE tube, because I was unable to find a generic tube small enough that could be adapted (the smallest I saw was in the 45 mm ID range). I can also find small metallic tubes (I have one), but probably they will resonate.
Old 22nd July 2011, 09:16 PM   #7
Small bump.
Nobody order from PE?
Ralf
bass reflex tube phase behaviour Helmuth Multi-Way 4 21st January 2009 03:02 PM
WTB: Rane Pe-17 Cloth Ears Swap Meet 0 29th October 2008 02:15 AM
No bass reflex tube? Williham Multi-Way 2 12th December 2007 09:49 AM
PE purchased AC W3-871 coming to PE RAW Full Range 4 2nd November 2005 07:21 PM
PE purchased AC W3-871 coming to PE RAW Multi-Way 18 15th September 2005 02:38 PM
Page generated in 0.08747 seconds (78.14% PHP - 21.86% MySQL) with 10 queries
