| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Time to clear out some drivers that I am not currently using. I sure wish that I lived in somewhere bigger than my 440 square foot apartment!
Eton 5-880 (pair) $125 Excellent midrange driver. Less than half new price. Cosmetically excellent and used less than 20 hours. Always crossed over above 150hz. Perfect for a high end 3 way, center channel or mini monitor. https://www.madisound.com/store/product_info.php?products_id=229 Vifa M13SG-09 (pair) $45 Very nice shielded 5” driver. Cosmetically excellent, used only to test against the Etons. Always crossed over above 150hz. Perfect for a high end 3 way, center channel or mini monitor. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=297-304 Morel MDT55 (pair) $80 or (2 n ir) $150 2” dome midrange. Never used, I bought a ribbon tweeter that is crossed over at 1500hz so never used these. A nice dome midrange is something special as fans of the Yamaha NS-1000’s and 690’s can attest to. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=287-020 Peerless XXLS 10” 830843 (pair) $150 10 subwoofer. Very good condition with only flaws being some rubbing in the screw holes and blue-tac residue on the back where I had them mounted. I used them for about 30 hours when testing against the Eton woofers that I kept. They produce big tight bass however I wanted a ported cabinet and they are better in sealed. http://www.madisound.com/pdf/peerless/830843.pdf MB Quart OM160 (pair) $20 6.5 midwoofers. Meant for car install from the time when MB Quart made high end products. They are in fair shape, certainly used, and one dust cap is dented. They sound great though and are quite efficient. They both measure at 3 ohms. Celestion 8” woofers and passive radiators. (pair of each) $50 Pulled from working speakers so I could use the cabinets for another project. Great shape and well built. Both have rubber surrounds and both measure 5 ohms. Celestion 5” midwoofers (pair) $20 Same story as the woofers. Rubber surrounds and measure 3.8 ohms. Pair of B&W DM4 speakers. $50 They are in poor cosmetic condition but work well. Available for local pickup or as drivers. |
#2 |
Hello
PM sent Greetings Gabor |
#3 |
Hello
Please let me know the shipping cost to Toronto on the Peerless woofers. If not to much I'll take them. Greetings gabor |
#4 |
The big peerless woofers will cost $35 to ship to Toronto. They come boxed with their original foam so they will be safe.
#5 |
peerless woofers
im also interested. |
#6 |
Take them please.
To me 8" woofer size the best. The biggest problem my ribbon tweeters 91db, mids 92db, 87db woofer not ideal to me. Greetings gabor |
#7 |
price for xxls woofers shipped to norway?
/////Alpine, Peerless, Stinger |
#8 |
UPDATE
Time to clear out some drivers that I am not currently using. I sure wish that I lived in somewhere bigger than my 440 square foot apartment! Eton 5-880 (pair) $120 Excellent midrange driver. Less than half new price. Cosmetically excellent and used less than 20 hours. Always crossed over above 150hz. Perfect for a high end 3 way, center channel or mini monitor. https://www.madisound.com/store/product_info.php?products_id=229 Vifa M13SG-09 (pair) $40 Very nice shielded 5” driver. Cosmetically excellent, used only to test against the Etons. Always crossed over above 150hz. Perfect for a high end 3 way, center channel or mini monitor. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=297-304 Peerless XXLS 10” 830843 (pair) $150 (PENDING SALE) 10 subwoofer. Very good condition with only flaws being some rubbing in the screw holes and blue-tac residue on the back where I had them mounted. I used them for about 30 hours when testing against the Eton woofers that I kept. They produce big tight bass however I wanted a ported cabinet and they are better in sealed. http://www.madisound.com/pdf/peerless/830843.pdf MB Quart OM160 (pair) $20 6.5 midwoofers. Meant for car install from the time when MB Quart made high end products. They are in fair shape, certainly used, and one dust cap is dented. They sound great though and are quite efficient. They both measure at 3 ohms. |
#9 |
Peerless are still available, please expect $55 for shipping in the USA.
Norway shipping is $125, yep, I know, but that's 16"x12"x12" and 30lbs from Canada, postal code V8T3P4 if you would like to check. |
#10 |
Got a ballpark on shipping to the US on those MB Quarts? Thanks!
Oh, and would you happen to know top-mounting depth? No other car audio bits to part with, I assume? |
| Need to unload some speaker drivers | InclinedPlane | Swap Meet | 0 | 4th January 2010 05:23 PM |
| HT speaker drivers!! | BannoIB | Multi-Way | 1 | 28th May 2007 02:53 PM |
| FS: speaker drivers | ycl | Swap Meet | 0 | 15th September 2005 06:40 AM |
| RCF speaker drivers | djdan | Multi-Way | 3 | 1st December 2004 08:25 AM |
| Speaker drivers | soundguymark | Multi-Way | 0 | 8th April 2004 03:26 PM |
| Page generated in 0.12276 seconds (81.74% PHP - 18.26% MySQL) with 10 queries |
