| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
For sale is an almost new Crown XLS-1000 class D amplifier weighing only 11 lbs. This amp was purchased for a PTA event and has logged about 3 hrs of use. It is in perfect condition and includes all original packing material, manual, box, etc.
The cooling fan is absolutely silent and is thermostatically controlled. Built in 4th order LR digital crossover variable from 50Hz to 3000 Hz on 1/12 octave centers. Can be set for highpass or lowpass (both channels), crossover (1 high + 1 low), bridge mode and bypass. XLR, 1/4" and RCA inputs. Binding post and Speakon outputs. 550W per channel @ 2 ohms 350W per channel @ 4 ohms 215W per channel @ 8 ohms 700W bridge mode @ 8 ohms 1100W bridge mode @ 4 ohms $220 plus actual shipping ------------------------------- Manufacturers specs: XLS Drivecore Series XLS High Performance, Lightweight Class D amp weighs less than 11 lbs. Integrated PureBand™ Crossover System for better performance and control Peakx™ Limiters provide maximum output while protecting your speakers XLR, 1/4", RCA inputs provide outstanding flexibility Efficient forced-air fans prevent excessive thermal buildup Electronically balanced XLR inputs; touchproof binding post and Speakon® outputs Precision detented level controls, power switch, power LED, and six LEDs which indicate signal, clip and fault for each channel Attached Thumbnails |
#2 |
SOLD!
| Crown XLS 1500 | benz2k | Solid State | 5 | 28th March 2011 06:18 AM |
| Help with Crown XLS 2000 | butterfenco | Class D | 1 | 26th January 2011 01:03 PM |
| crown xls 602 | galush | Parts | 1 | 4th June 2009 01:40 PM |
| Crown XLS Problem | Impoliticus | Solid State | 11 | 21st April 2009 06:59 AM |
| FS: Crown D-75A Amplifier - MINT! | chops | Swap Meet | 13 | 21st March 2008 12:18 AM |
| Page generated in 0.06219 seconds (71.24% PHP - 28.76% MySQL) with 11 queries |
