| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I have 4 of these drivers for sale, low hours they are mounted in cabinets that are a design by Lynn Olsen, here is a link The Ariel and the ME2
Scroll up to good base. I am asking $100 each + freight and 4% PayPal. I will throw in the cabinets but it will have to be local pickup. Bill 25W/8565-01 24 cm bass driver with paper cone power handling (continuous/program) = 100 W resonance frequency fs = 19 Hz impedance R = 8 Ohm sound pressure level SPL = 88 dB (2,83V; 1m) DC resistance Re = 5,5 Ohm effective piston radiating area Sd = 330 cm2 effective mechanical mass incl. air load 47 g equivalent volume of compliance Vas = 229 l total Q factor Qts = 0,34 (Qms=5,6, Qes=0,36) maximum peak linear excursion vibration xlin = +/- 6,5 mm mounting diameter d = 228 mm overall diameter d = 255 mm |
#2 |
Here is a picture of the cabinets,
Bill |
#3 |
...truth seeker...
We have traveled the same path. I have 4 already. That is an exceptional offer.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#4 |
Wish I was living in the US
#5 |
They are good drivers and cabinets, I could never get the tuning with my speakers to work out. A shame I have a interested buyer for the drivers without the cabinets. The cabinet construction was as Lynn recomended 3/4 Baltic burch , 4 braces Swiss cheesed, one side dampened. Quite a bit of time though I could have done better on the finish.
bill Last edited by wirewiggler; 29th May 2011 at 05:31 PM. |
#6 |
Sometimes a square peg fits a round hole just fine
wish i was over there, would snap this deal up
#7 |
I'm in Bakersfield if you're looking to trade for anything. Send me a PM
#8 |
I have a pair that I am using in an identical application. I had the same issue getting them to integrate. They always ended up sounding boomy and a bit of that "one note" bass syndrome. I ended up moving them into sealed boxes last year. I know I lost a lot of bass extension, but the tuning became easy. With a bit of bass boost down around 25 hz, they do a great job.
#9 |
Dave,
My problem exactly what did you end up with for a box ? May go that route as no buyers have panned out. Bill |
#10 |
I don't know off hand. I could measure this weekend when I am home. I just used the factory specs and did a calculation for a sealed box. I uses a .707 Q and moved on. In fact I was able to cut down my ported boxes to about 1/2 the size for the sealed box. It only cost me my time and the price of glue.
I found that the heavy cone of that driver just didn't have the control I was looking for with the soft air spring of a vented enclosure. The tight spring of the sealed box made it very musical, though lacking the ultimate bass extension. What I found strange is that for years ProAc used that same driver in a very small vented sub. I'm not sure how they did it, but it was very nice. I borrowed one from my local shop for a while before buying the ScanSpeaks to build my own. I can't believe nobody is snapping those up at that price. They just need the right box. I am now considering building them into a 3 way with a ribbon, 4" mid and 10" sealed sub. With a well designed crossover, it would be truly world class. |
| 4 x Scanspeak 25w/8565-01 | boidos | Swap Meet | 0 | 13th February 2011 11:33 PM |
| FS: 2 Scan-Speak 25W/5565A00 4-Ohm 10 in | omarmipi | Swap Meet | 8 | 26th March 2009 06:58 PM |
| FS: Scan Speak 25W/5565A00 4-Ohm 250mm (10") subwoofer | omarmipi | Swap Meet | 2 | 14th June 2007 04:21 PM |
| Scan-Speak 8565-01 10" New | Fritz | Swap Meet | 1 | 19th April 2005 04:53 AM |
| ScanSpeak 25W 8565-01 | Fritz | Swap Meet | 0 | 21st December 2004 03:12 PM |
| Page generated in 0.10874 seconds (79.04% PHP - 20.96% MySQL) with 11 queries |
