Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 6th May 2011, 03:27 PM   #1
Default WTB: strobe disc-light
I want to buy a keystrobe disc & light 50HZ
Old 6th May 2011, 05:28 PM   #2
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
This light couldn't be much easier to build. Mine took about $5 and less than an hour. I used a thrift store transformer and crammed the whole thing into an old DIN plug. As he says, you can use excel to make a disc.
Vinyl Asylum: Simple Strobe using LED by Mark Kelly
Vinyl Asylum - No diagram - Mark Kelly, August 10, 2006 at 06:12:53
Vinyl Asylum: 60 Hz disc by Mark Kelly
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 6th May 2011, 05:57 PM   #3
If you want to try something easily available, download my arc template generator. It also prints out 50 and 60 Hz strobe disks at any scale you like. The quality is way better than images, since it generates the pattern locally. It's even better if you use photo paper to print it. I'm not sure how stable the line is where you live, but in many places the use of a quartz stabilized light is a bit pointless. In other places it makes a lot of sense. It takes more time but you can double check using 50 or 100 revolutions and timing with a stopwatch.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 7th May 2011, 11:31 AM   #4
Here are a couple of LED strobe circuits - your choice of quartz or
mains driven -
Very simple LED strobe - AudioKarma.org Home Audio Stereo Discussion Forums
http://h-6.abload.de/img/stobe-zd75k6bv.jpg
Old 13th May 2011, 10:46 PM   #5
Paul
Thanks for your help!
Mark Kelly's simple strobe works better than videos image
YouTube - simple stroboscope light !
Old 14th May 2011, 09:52 PM   #6
pjanda1's Avatar
No problem!
Paul
Old 15th May 2011, 02:06 AM   #7
stokessd's Avatar
Not To toot my own horn too much, but I've had a strobe disk up on my website for like 13 years:
http://quadesl.com/pdf/strobe.pdf
Print, cut, and go
Old 15th May 2011, 09:49 AM   #8
Thanks, Sheldon.
How did you generate the disk?
There's an interesting postscript program I found here -
Re: Strobe circle
The postscipt program above can be modified for 50hz
using the strobe icon count formula on Sheldon's disk
(or here -
HOW STROBES WORK AT KABUSA.COM
50 hz 33.33 rpm - change t33 to 90.
For 45RPM, in 50Hz the exact number of strobe dots is not
an integer number.
An approximation is to set t45 to 133, giving
45.1127 rpm
Old 16th May 2011, 05:04 AM   #9
Less fancy solution.
If you have an Ipod Touch. Get frequency generator app, connect Ipod to to amp. Then LED to amp speaker output. Pure fun.... :-)
Old 16th May 2011, 09:25 PM   #10
One more-blue led
YouTube - simple strobe light
Turntable Strobe Lights dhaen Vendor's Bazaar 0 29th December 2007 08:37 AM
Strobe Lights and Bass CARTRulz Subwoofers 10 10th September 2006 12:36 PM
WTB: 250w HQI light kit tetutigre Swap Meet 1 8th September 2004 03:43 PM
Turntable strobe dhaen Swap Meet 4 6th March 2004 08:53 AM
Page generated in 0.13586 seconds (70.16% PHP - 29.84% MySQL) with 11 queries
