$99 plus shipping PAYPAL
About 15 years old. It's used.
Powered mostly with a 300B amp, a little with a 100w SS amp.
White paint on it damps the magnet structure a little (tiny glass spheres)
Center channel?
Volt Loudspeakers - RV3143
"FEATURES: The RV3143 is a unique loudspeaker. It features two cooling systems. In addition to the conventional rear vented magnet it uses the patented, front mounted, Radial chassis which acts as a giant heatsink. This keeps voice coil and magnet temperatures exceptionally low resulting in superb reliability, 3dB less power compression and tight, clean bass even after prolonged operation at maximum power. By maintaining low voice coil temperature there is less change in the Thiele-Small parameters thus system alignment is better maintained after prolonged high power operation. The RV3113 has a symmetrical field magnet for absolute linearity and transient control on high power peak inputs. Innovative design has produced a breakthrough in performance and reliability."
Center channel?
