Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 27th March 2011, 01:37 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Jensen JE-346-AX MC step up transformers
Pair of Jensen JE-346-AX Moving Coil step up transformers. there is published info on the web that these are also used as ribbon mic step up transformers.
apparently these are some of the best MC step ups available. and look at the freq response of these bad boys!
JT-346-AX can be wired for either 1:4 or 1:12 step up ratio.
specifications:
Bandwidth -3dB, 1:4: 0.3Hz – 220kHz
Bandwidth -3dB, 1:12: 0.3Hz – 200kHz
Deviation from linear phase, 1:12: +1.0 degrees typical
Noise figure, 1:12: 1.4dB at 5Ohms
Common mode rejection, 1:12: 145dB at 60Hz
Fully balanced primary
Primary may be reversed for polarity inversion
Double magnetic shield
apparently this MC step up is unobtanium now. Jensen only makes JT-347-AX which sell for US $250 each. JT-347-AX frequency band is only half of of the 346 transformers (0.4Hz – 100kHz) and common mode rejection is 20dB (10x) worse than that of the 346 from what i have read. But this info is quite old and may not be very accurate anymore. I have also read that Jensen may still make a 346 but a 346-AXT version
Looking for serious offers.
Info from Jensen on 1:4 ratio
www.jensen-transformers.com/datashts/346ax14.pdf
Info on 1:12 ratio
http://www.jensen-transformers.com/d...s/346ax112.pdf
It's not about what you can BUY...It's about what you can BUILD!
Simulation of the JE-990 OP Amp By Deane Jensen PB2 Solid State 16 12th April 2012 06:20 PM
MC Step-up transformers mantisory Analogue Source 44 14th August 2007 06:30 PM
FS: VSPS phono preamp & tamura MC step up transformers. rjm Swap Meet 0 25th August 2005 05:42 AM
Jensen JE-112-PC line output xfmrs MRehorst Swap Meet 0 24th July 2002 04:13 AM
Jensen JE-11P-1 Xfmrs for sale MRehorst Swap Meet 0 23rd July 2002 04:08 AM
Page generated in 0.05875 seconds (75.54% PHP - 24.46% MySQL) with 10 queries
