Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS - Simpson 555 Tube Tester - works
Old 10th March 2011, 11:34 AM   #1
feke67 is offline feke67
Default FS - Simpson 555 Tube Tester - works
FS - Simpson 555 tube tester.
Working with back-lit meter and working locking case with handle. USA made and designed, very cool bakelite top. This tube tester has the roll chart so you can scroll and find the parameters for measuring your tube.
I am told by previous owner that this is an early tester so it will not test 6550s, 6CA7s, etc. It will test many of the 4 pin triode tubes. It tests hundreds and hundreds of tubes. It will test the 2A3, 45, 6V6, 6L6, 5V4, 5U4, 6SN7, 6SL7, 12ax7, 12au7, 12at7, etc. I tested a few different types of tubes and it worked well. It has line adjustment, tests for quality, shorts, and leakage.
Simpson is known for its high quality analog multi-meters. This unit brings the same quality to a tube tester.
I recently purchased this to test some tubes in a noisy amp so that I could roll different tubes thru the amp. A friend has a tube tester as well, so I no longer need this one.
Email for pictures.
$95 obo.
Thanks.
FS - Simpson 555 Tube Tester - worksHide this!Advertise here!
simpson 330 tube tester brians Equipment & Tools 3 20th September 2014 06:22 PM
FS: Military Tube Tester speaker Swap Meet 2 28th September 2010 12:01 PM
FS: Hickok 539B Tube Tester Zero Cool Swap Meet 2 17th February 2009 05:15 PM
FS: Simpson 260 Vintage VOM Zero Cool Swap Meet 0 15th July 2006 06:50 PM
FS or trade new tube tester elviukai Swap Meet 3 24th May 2004 07:20 AM
Copyright ©1999-2017 diyAudio
