Shed Clearance –need to clear out my old shed so I can knock it down & build a bigger one! It’s all gotta go, make me an offer…
Dual cone drivers, pairs, 8”:
RS 40-1286C as new
MSP 8TAX 15 ohm alnico
Magnavox 8P1X 15 ohm alnico, a bit rough cosmetically
MSP 96PSX 15 ohm alnico 6”x9” damared cones
Woofers:
Single Jaycar CW2142 8” carbon fiber cone 120W (& 50L box if you want it)
Single Altronics C3024 8” Poly woofer (& 30L box if you want it) (these are still available)
EV T35A tweeters pair, ceramic magnets, a bit rough cosmetically
Akai GX4000D tape recorder + ~40 reels of tape
ECC83 Philips used ~ 30, scavenged from an organ 40 years ago
Valve transformers:
Hammond transformers from aforementioned organ:
Pair of output transformers for 6L6 amp ~ 25W, 6600:8 Ohm
Pair of power transformers to match, one rated at 125VA, no load voltage 330-0-330, the other which has a massive heater winding for all those valves, 180VA, no load voltage 360-0-360. Both have 6.3 & 5V secondaries, & dual voltage primaries.
I have repainted these with grey crackle finish, they look great.
5 or 6 sets of Power Transformer + pair of OPTs for low power SE amps, both 8k & 10K scavenged from old Radiograms
Happy to deliver in Western Sydney, elsewhere in Aus, PM me…
RS 40-1286C as new
Woofers:
Valve transformers:
PM sent about the ECC83 Philips
Dangit!
Take 'em now or the bin gets it!!
Dual cone drivers, pairs, 8”: $10 for all 4 pairs...
RS 40-1286C as new
Woofers: $15 Ea
EV T35A tweeters pair, ceramic magnets - $15
Akai GX4000D tape recorder + ~40 reels of tape: $20
5 sets of Power Transformer + pair of OPTs for low power SE amps, both 8k & 10K scavenged from old Radiograms - build youself a guitar amp : $10 per set
RS 40-1286C as new
Woofers: $15 Ea
