Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Bottlehead S.E.X. Transformer and Choke Set
Old 27th February 2011, 07:42 PM   #1
HiGHFLYiN9s is offline HiGHFLYiN9s  United States
HiGHFLYiN9s's Avatar
Default FS: Bottlehead S.E.X. Transformer and Choke Set
Up for sale is a never used set of Transformers and Chokes for the Bottlehead S.E.X. (single ended eXperimenters). $60 shipped in the CONUS, international a little extra.
My DIY Electronics Blog: DIYAudioBlog.com
Old 27th February 2011, 11:07 PM   #2
gmant123 is offline gmant123  Argentina
gmant123's Avatar
Default Data
Hi, could you give me some technical specifications?
Alberto.
Old 27th February 2011, 11:16 PM   #3
The 2 Specos output transformers have the following:
4 or 8 Ohm Secondary Impedance
10, 5, 2.5, 1.25 and 0.62 Wattage Taps
Color Coded Leads
The 2 chokes each have four solder points, not really sure where to find the specs for them though.
I will take $35 for the set of these, didn't realize the Specos were only worth about $12 a pop from Allied.
Old 27th February 2011, 11:30 PM   #4
gmant123's Avatar
Hi:
Secundary 4 and 8ohm ok.
Primary 10k, 5k, 2,5K,1,25K and max 0.68W ?
Thank You!!!
Old 28th February 2011, 01:42 AM   #5
Looks like 10 watt max:
Speco 10 Watt, 70 Volt Line Transformer Speco's 70 volt 10 watt line transformer has wattage taps. It has 10, 5, 2.5, 1.25, and 0.625 watt taps.
The chokes are actually made by Bottlehead. I noticed they actually have 5 solder points each and are called the Bottlehead PC-1 (30H 35mADC), series wired, coil 1 goes from tap 1 to 4, coil two goes from 5 to 8.
Old 4th March 2011, 03:53 PM   #6
$35 shipped ... any takers?
Old 3rd June 2011, 08:39 PM   #7
patkhan1 is offline patkhan1  Chile
Nada
patkhan1's Avatar
Do you still have them?
Old 9th February 2014, 09:13 PM   #8
Williston is offline Williston  United States
Default I don't suppose...
that you still have this set of transformers for sale?
thanks
Peter
FS: Bottlehead S.E.X. Transformer and Choke SetHide this!Advertise here!
FS: Bottlehead Paramount amplifiers built by Bottlehead johnsonad Swap Meet 2 28th October 2010 01:35 AM
Bottlehead Filament Choke FC-1 for Push-Pull? Kashmire Tubes / Valves 0 19th January 2010 03:13 AM
FS: Hammond 1627SEA output transformer + 193H 5H choke marcutan Swap Meet 3 5th May 2008 02:12 AM
FS - Bottlehead Foreplay III john65b Swap Meet 2 16th July 2007 04:14 AM
Bottlehead Foreplay FS idex Swap Meet 3 9th January 2006 12:23 AM
