| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
#21 |
Same limitations exist.
#22 |
Will replacing the passive i/v with an active i/v help?
#23 | |||
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
To answer your final question - if the output signal is being limited by the TDA1541A's output compliance, then active I/V might solve the problem. But the fact that you are getting 200mV p-p signal (as predicted by theory) makes me think this is not the issue - so I'll venture that active I/V will make no difference.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#24 |
Since the DAC has a current limit of 4 mv, if the clipping is not in the digital section, shouldn't we be able to raise the voltage and avoid clipping with a properly constructed active i/v?
#25 |
I have apprised Mr. Zou of the problem. I am sure he is looking into it now and will get back to me soon.
| which clock for analogmetric tda1541A dac kit | Chilli6565 | Digital Source | 4 | 6th May 2010 12:41 PM |
| FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete | krishu | Swap Meet | 0 | 17th December 2009 09:33 AM |
| Recommend a DIY tda1541a dac kit? | boidos | Digital Line Level | 2 | 6th August 2009 01:43 PM |
| TDA1541A Chineese DAC KIT | UV101 | Digital Source | 8 | 10th February 2009 10:46 AM |
| FS: Partially complete TDA1541A DAC kit | Strohmie | Swap Meet | 2 | 2nd September 2004 01:07 AM |
