16 Vifa AP13FG21-04 full range drivers.
Bought these to make a small line array but lost interest. Un-used.
They have a nice response, vented and copper plated pole piece.
Specifications: * Power handling: 70 watts RMS/100 watts max * Voice coil diameter: 1" * Voice coil inductance: .51mH * Impedance: 4 ohms * DC resistance: 2.92 ohms * Frequency response: 65-12,000 Hz * Magnet weight: 14.6 oz. Fs: 91.7 Hz * SPL: 92 dB 2.83V/1m * Vas: .14 cu. ft. * Qms: 3.12 * Qes: .80 * Qts: .637 * Xmax: 4.5mm * Net weight: 1-1/2 lbs. * Dimensions: Overall Diameter: 5-1/8 ", Cutout Diameter: 4-7/16 ", Mounting Depth: 2-3/8 ", Magnet Diameter: 2-7/8
$150 for all ?
One pair of used but serviceable ScanSpeak 18w8546 yellow coned 6.5" kevlar
https://www.madisound.com/store/prod...oducts_id=8730
$125 plus shipping
2 - Audax PR240-Z0 woofers
AUDAX, LA PASSION DU HAUT-PARLEUR
Would make a really good woofer in a 3-way 8ohm 95db efficiency
These are un-used
$100 ?
John
$150 for all ?
$125 plus shipping
These are un-used
$100 ?
John
Hi John, I'd like some more info on the Audax PR240-Z0 woofers. The link doesn't seem to work anymore, and a quick internet search turned up nothing. Any specifications you can give me? Is the "95 db" you quoted 1w/1m? What size are they? What kind of shape are they in? Thanx.
They are 10" aerogel cones, unused
Try this link
I mis-spoke on the efficiency it appears
http://www.audax.com/archives/pr240z0.pdf
