| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Selling two 1 1/8" Silk dome tweeters model 9930-20 and four 7 inch carbon fiber/paper woofers model 8935A. All drivers matched at the Usher factory. They were removed from a brand new pair of Usher tower speakers shortly after being purchased from an authorized Usher dealer. All have less than 50 hours use and are in perfect shape and look brand new.
Asking $250 for the entire package plus shipping. Please respond to this posting or e-mail me at cinellipro@hotmail.com. Specifications: 9930-20 Power handling: 10 watts RMS/15 watts max (full range signal) *VCdia: 1-1/8" *Impedance: 8 ohms *Re: 4.7 ohms *Frequency range: 1,800-20,000 Hz *Fs: 660 Hz *SPL: 88 dB 2.83V/1m *Dimensions: A: 4-1/8", B: 3-1/4", C: 1-3/4". 8935 Power handling Pe 60 W Reference efficiency @ 1 W / 1 m 87.0 dB/W/m Nominal impedance 8 ohm Voice coil resistance Re 5.80 ohm Voice coil diameter 38.0 mm Voice coil height 16.0 mm Max linear excursion Xmax (+/-) 5.00 mm Thiele-Small parameters Resonance frequency fs 32.0 Hz Equivalent volume Vas 44.0 dm3 Total quality Qts 0.37 Electrical quality Qes 0.44 Mechanical quality Qms 2.35 Effective piston area Sd 150.0 cm2 Mechanical compliance Cms 1.4 mm/N Moving mass Mms 17.400 G Bl product 6.8 N/A |
#2 |
...truth seeker...
shipping from where?
do you have crossovers and/or a schematic?
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#3 |
Ed,
Please go to the following website for the schematics of the drivers. Thanks. www.loudspeakershop.eu - Usher Audio |
#4 |
Did they came of the V-604 speakers?
#5 |
Yes they were taken from the V604 loudspeaker.
#6 |
...truth seeker...
shipping from where? where are you?
do you have a schematic of the crossover or the actual crossovers themselves?
#7 |
South Florida.
| woofers FS: Usher & TB | Ang | Swap Meet | 3 | 23rd July 2010 01:42 AM |
| FS: Usher 8945a woofers | Ang | Swap Meet | 1 | 13th January 2008 03:36 AM |
| FS: Usher 8945A 7" woofers | Wanderer | Swap Meet | 9 | 28th March 2007 02:02 AM |
| FS: Usher 9950 Tweeters | dunderchief | Swap Meet | 3 | 18th April 2004 05:44 AM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.09226 seconds (80.69% PHP - 19.31% MySQL) with 11 queries |
