FS: Dali Suite 2.8 cabinets, drivers, and crossovers - $750
I have a modified pair of Dali Suite 2.8 speakers for sale. Good starting point if you're looking to save some work building cabinets or want speakers ready for a biamp project. The contents are
- cherry finish Suite 2.8 cabinets (front port is tuned to 40Hz)
- three Vifa BC25TG19 tweeters
- four OEM variants of the Vifa XT18WH09-08 woofer with a different dust cap
- original Dali second order passive crossovers, boxes, spikes, and manual
- internal wiring upgraded to AWG 10 zip cord and ring terminals
Currently the drivers are unwired and the passive crossovers removed as I've been operating the speakers biamped---suggested crosses are 1.8kHz LR4 or 2kHz LR6. The internal wiring and/or passive crossovers can be reassembled at your option. The cabinets will accept 100mm diameter tweeters and 180mm woofers without modification, are about 45 liters each, have basic damping installed, and have a separate compartment behind the binding which can hold passive or active crossovers, class D amps, and maybe even low power class AB.
USD 750 plus shipping 92 pounds from zip code 97701 in the US. If you're in the Pacific Northwest or northern California I'm willing to drive a couple hours out of the way to meet up and save you the shipping. I travel between central Oregon and the Seattle area roughly monthly so if you're not in a big hurry that couple hours expands to a good chunk of Oregon and Washington.
