Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Gold plated or Rhodium plated connectors are better
Old 17th June 2010, 05:26 AM   #1
gaborbela is offline gaborbela  Canada
Default Gold plated or Rhodium plated connectors are better
Hello
I would like to know if there is any difference sound wise between the gold plated connectors , binding post or the Rhodium plated .
Please if you have any experience share it with me .
Thank you very much
Greetings
Old 17th June 2010, 05:49 AM   #2
ChrisR1983 is offline ChrisR1983  United Kingdom
Hi
I think you posted in the wrong place but...
I use cardas rhodium and I don't really like them. I can't tell a difference in the sound but gold is a lot easier to get hold of and usually cheaper. I'd go for gold.
Cheers
Chris
Chris R
Old 17th June 2010, 05:56 AM   #3
sangram is offline sangram  India
A lot of boutique Japanese manufacturers use nothing but nickel-plated brass for their connectors and interconnects. Even on the highest-end Shindo aplifiers, all you see is regular nickel sockets and plastic-capped binding posts, nothing fancy at all.
I've been using regular Switchcraft nickel-plated RCAs with silver and/or silver-copper alloy wires twisted together (similar to what Shindo does with theirs) and the results are simply stunning. I get a local jeweller to make the wire, sleeve it with some cloth and solder the (very basic) RCAs to it.
More than sound, I think the plating affects the life and corrosion resistance, and therefore durability of the plug/socket. Gold plated connectors seem to dull or wear out, the Rhodium plating on the Cardas I also use seems to look like new even after hundreds of insertions. I think that the better contact and durability plays a bigger role in the sound quality than absolute properties of the metal itself.
Old 17th June 2010, 06:10 AM   #4
Thank you very much .
I have the same experience with gold plated connectors , they don't last long .
Since I do lot of testing very easy wear out .
I never tried rhodium so that is the reason I ask .
Greets
Gold plated or Rhodium plated connectors are betterHide this!Advertise here!
Best way to solder gold-plated components? bst Tubes / Valves 24 24th March 2010 12:13 PM
Gold-Plated Screw Terminals Tyimo Parts 10 22nd September 2009 08:31 AM
Gold Plated BNC Hardware fmak Digital Source 129 26th March 2005 05:25 PM
Gold plated jacks to... johnferrier Everything Else 1 21st December 2003 05:09 AM
Aren't gold plated connectors supposed to be inoxidable? Bricolo Parts 31 28th November 2003 02:19 AM
Copyright ©1999-2017 diyAudio
