Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 15th June 2010, 02:19 AM   #1
vaughn is offline vaughn  United States
Default FS Arjenhelder Tripath TA2020 amp with rechargeable SLA supply
This has amp works well with a wide range of speakers and might embarrass your current amp if you have high efficiency Klipsch, Altec, etc. It is the MKIII version of ArjenHelder's Tripath TA2020 amp. Info here;
New MKIII Tripath TA2020 PCB 25watt Class-T amplifier - eBay (item 260617395305 end time Jun-19-10 17:19:11 PDT)
I built it into an aluminum pan with nice quality binding posts and input jacks. I installed a DPDT switch on the front panel that in the down position charges the SLA battery and in the up position powers the board from the battery(completely removing the charging unit from the circuit). The DPDT switch is a center off model so it must be in the down position to be charging. Bottom plate is 1/2" acrylic and the overall dimensions are 12" deep x 8 5/8" wide x 4 3/4" tall and about 10lbs. Trickle charger included, of course. I have been able to run my stereo all day from a charge and you should be able to do the same unless; your speakers are very inefficient or you listen very loud for extended periods. Asking for $150 plus shipping.
Old 15th June 2010, 08:23 PM   #2
Now $150 shipped in the lower 48...
FS: Tripath TA2020 chip mdlover Swap Meet 5 30th November 2010 06:06 AM
FS: Arjen Heldar's 3 x Tripath TA2020 PCB = 6 channels total with integrated SMPS Galgo Swap Meet 3 7th August 2010 02:17 PM
FS: Tripath TA2020 2-Channel Class-T Amplifier IC ralphs99 Swap Meet 4 7th May 2009 11:30 PM
Tripath TA2020 4 Channel Amp john65b Swap Meet 11 30th April 2009 11:42 AM
Tripath TA2020-020 6 Channel Amp Board john65b Swap Meet 0 10th October 2005 12:20 PM
Page generated in 0.06905 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
