Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 9th May 2010, 08:15 PM   #1
Default The valve amp builders tool kit
The Valve Amp Builders Tool Kit
Do you experiment with making valve gear? Read on!
Heathkit IP-17 High voltage PSU.
Very good quality PSU, with the following features;
Adjustable positive rail of 10-400v with settable current limiting of 5 to 100 mA, common can be lifted from ground
Adjustable Negative rail of 0-100v @1ma, common can be lifted from ground
6.3v AC @ 4 amps or 12.6v AC @ 2 amps for valve filaments
Current meter for positive rail
Voltmeter switch able between positive or negative rail
More info see;
http://www.nostalgickitscentral.com/...chema_ip17.gif
http://www.nostalgickitscentral.com/.../test/ip17.txt
I have tested this (see pics) and as far as I can ascertain it is all working well. The filament supplies read 6.9v & 13.8v. The 400v output actually reaches 412v, & the -100v goes to about -125v. There is about 2mv of 50Hz ripple on the positive rail output. I haven’t tested the current limiting.
This unit is in very good condition cosmetically, and has been assembled to a very high standard.
And
Heathkit IG-82 audio sine/square generator
Again a very good quality piece of kit.
20Hz (see below) to about 750kHz.
0 to 10v output, although this drops away at the frequency extremes
Separate sine & square outputs.
I have tested this (see pics) and it seems to work well apart from when the X1 frequency multiplier is selected the output is unstable. Maybe the switch needs cleaning? Both the sine and square waves are nice and clean and the frequency scale is really quite accurate.
As above, the unit is cosmetically very good and assembled to very high standard.
More info see;
http://www.nostalgickitscentral.com/.../test/ig82.txt
http://www.nostalgickitscentral.com/...chema_ig82.gif
Both items run on UK mains voltage. As with all second hand electrical equipment you should have it thoroughly checked over by a qualified electrician for safety.
These units both contain valves, so are quite delicate and are quite heavy, (about 15kg) so I really don’t want to post them as I can’t promise they will arrive unscathed. I live in Walthamstow, NE London for pick up or I could meet, within reason, half way. If you really want it posted I will, at cost, but I'm rather apprehensive about it. And lastly, I’m looking for £120 for the pair. Drop me a line for any more details. Oh, and the Multimeter and Oscilloscope are not included!!
You may notice that I have only posted twice on this forum, but I do have a good solid record on The Hifi Wigwam, if you should care to visit.
The photos in order are;
Power supply unit general view
Frequency generator general view
PSU interior
PSU positive rail max output
PSU negative rail max output
PSU filament voltage
FG scale check @1kHz
FG sine wave
FG square wave
Old 10th May 2010, 09:21 AM   #2
mgm31 is offline mgm31  France
I'm interested in the HV power supply.
May I know the price and shipping cost to France ?
Old 11th May 2010, 07:55 PM   #3
PM sent
Old 13th May 2010, 08:13 AM   #4
Bump.
Old 13th May 2010, 02:26 PM   #5
I'd nab that kit in a heartbeat--if only you were closer!!
Old 19th May 2010, 08:30 AM   #6
Some one else in Canada was interested, but it seems that surface mail to Canada does not exist any more, only air freight! Some much for carbon footprints...
The upshot is that the shipping (Aircrafting?) would be about £80.
Old 26th May 2010, 08:38 AM   #7
I now have found the construction manuals for both these items.
Old 28th May 2010, 04:08 PM   #8
Bump
Noise in a valve headphone amp kit hornloaded Headphone Systems 6 4th January 2010 09:06 PM
Horn builders tool - diy rip fence/guide quadtech Full Range 9 9th May 2009 07:23 PM
Decent Valve Amp Kit? Brap Tubes / Valves 9 20th May 2005 07:42 AM
Cheap valve amp kit... Anyone else thinking of having a try ? adharvey Tubes / Valves 5 30th June 2003 10:07 PM
Cheap valve pre-amp kit - comments please... adharvey Tubes / Valves 3 21st June 2003 08:51 AM
Page generated in 0.09969 seconds (83.37% PHP - 16.63% MySQL) with 11 queries
