FS: DIY 2A3 SET amp, or for parts FS: DIY 2A3 SET amp, or for parts - diyAudio
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 11th April 2010, 09:42 PM   #1
Saurav is offline Saurav
Default FS: DIY 2A3 SET amp, or for parts
I've tinkered with this for many years, and I've recently switched from HE speakers to dipoles, so it's time to move in a different direction. The amp works fine and sounds good, but I'd recommend buying it only if you are comfortable working on it. I don't have a schematic, and there have been multiple mods made over the years, so there will be some reverse-engineering required.
Parts:
OPT: One Electron UBT-3
PS transformer, choke, heater transformers: Hammond
Caps: PS electrolytes are Nichicon, coupling caps are Russian surplus (I think teflon)
Tubes: Sovtek 2A3s (I have 2 matched pairs, one set is several years old, the other probably a couple of years old), JJ 5AR4 and ECC99s
The topology is pretty simple. It started as a schematic I found on the JE Labs website, then evolved from there. The PS is a common CLC section with (I think) a 10H choke, then RCRC for each channel. The ECC99s have a battery under the cathode, and are RC coupled to the 2A3s.
I probably have around $400 in the iron, I think I once calculated the whole amp to be around $5-600 in parts. I'd like $150 + shipping, OBO. Paypal preferred. All that iron is heavy, so the closer you are to Portland Oregon, the less shipping will be
Feel free to post here / PM / email with questions.
Old 11th April 2010, 09:51 PM   #2
ra7 is offline ra7  United States
pm sent.
Old 11th April 2010, 10:27 PM   #3
d to the g is offline d to the g  United States
wildburro audio
d to the g's Avatar
I'll take a spot in line!
Old 11th April 2010, 10:38 PM   #4
mctavish is offline mctavish  Austria
Me three!
Old 11th April 2010, 10:57 PM   #5
Thanks for the interest. The amp is tentatively sold. If it doesn't work out, I'll contact the next person in line.
FS: DIY 2A3 SET amp, or for partsHide this!Advertise here!
FS: Hypex Electronics DIY Amp Parts eros28 Swap Meet 2 23rd October 2008 06:30 PM
Any advice on modifying a 2A3 SET amp to parafeed? zman3 Tubes / Valves 4 2nd March 2008 07:30 AM
Another SET 2A3 in the world lquintas Tubes / Valves 15 11th November 2007 04:20 PM
FS: 50W Aleph-X parts set including chassis tiroth Swap Meet 6 19th December 2004 02:34 PM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Copyright ©1999-2017 diyAudio
