Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 3rd April 2010, 11:02 PM   #1
Rodeodave's Avatar
Default FS: Valvo E88CC pinched waist ...
I'd part with one or both of these pretties. The print is not so good anymore but you probably won't hear that. Both tubes have shiny gold pins. Unfortunately I can't test the tubes, because I neither have tube gear where they would fit nor do I have a tube tester (or access to one).
The tube with the date code 7L2delta7A has the nice D-shaped getter.
The other tube has the date code 7L2delta6I.
Look at the pictures for further info. If you want pictures of some detail simply ask.
I have paypal and a bank account in Austria (Europe). I'll ship worldwide (insured) and won't skimp out on the packaging.
I also have some CCa and 6201 for sale... (or trade for a tube tester )
I'm not quite sure what they're actually worth, given I can't test them, so make me a "reasonable" offer. Comments welcome.
Gravity - Making the G since 13.7 billion B.C.
Old 4th April 2010, 03:42 PM   #2
Hello
What would be the price for 2 or 4 CCa Siemens tube ?
Please let me know .
It is hard to offer any amount because it is not tested .
Thank you
Greets
mathelaszlo2@yahoo.ca
Old 7th April 2010, 05:06 PM   #3
Rodeodave's Avatar
Thanks for your interest guys, but I decided to acquire a tube tester and check the tubes. Sorry for wasting your time (for now), I'll get back to you once I know more about them.
Old 8th April 2010, 09:54 AM   #4
Hi, I would definitely be interested in the Valvo PW tubes. Let me know when you get them tested and we can discuss $. Happy listening, Woody
Old 8th April 2010, 06:56 PM   #5
Rodeodave's Avatar
Okay!
Old 14th April 2010, 05:43 PM   #6
Default I am also very interested in your tubes - my email is sskoro1@hotmail.com
Old 17th April 2010, 04:12 PM   #7
Hi, I was wondering how you were comming with the tester concerning the Pinched Waist tubes ? Happy listening, Woody
Old 17th April 2010, 06:01 PM   #8
Rodeodave's Avatar
Hi, an Eico 666 is on it's way and as soon as I get it to work I'll check the tubes 'n report back.
Old 18th April 2010, 06:14 AM   #9
I am still interested in the Siemens CCa tubes after you are done testing them. Thanks again.
Greg
Old 3rd May 2010, 09:09 PM   #10
Rodeodave's Avatar
I finally got the Eico 666 tube tester. I overhauled it and also calibrated it (which is quite easy with an Eico 666).
I tested the CCa tubes and they test very good (one was bad).
Here are the settings I used (from the Coletronics chart from 1978):
6,3 50 50 6662145111 2 2 6-7-(8) 6
6,3 50 50 4512166611 2 2 1-2-(3) 1
I modified the Eico 666 so that I can directly measure the plate current. So the first number of the tested values is the % of dynamic conductance and the second value is the AC current through the tube. The tube obviously only conducts at the positive half-cycle of the anode voltage, which means that there is a factor of about .6 to get the real current, but that's just scaling.
All tubes tested negative for leakage (>20M Ohm) and gas.
The gas test with the Eico 666 goes as follows: The tube is tested with 0V applied to the grid. While holding down the merit lever the grid is switched from 0V to NC. A gassy tube would show an increase of current, with a good tube the reading drops.
Now the tubes:
1) 116/45.4 - 120/47.8
2) 121/49.0 - 120/46.5
3) 112/43.0 - 115/45.4
Matching code, ring-getter
Fs:e88cc Siemens Gold Pins rubydac Swap Meet 0 17th March 2008 04:08 AM
Siemens Valvo ED-8000 MartinV56 Tubes / Valves 2 18th September 2007 10:07 PM
Valvo C3m tubes with sockets. jean-paul Swap Meet 1 30th December 2006 01:57 PM
FS Mullard E88CC NOS pair Andypairo Swap Meet 2 11th September 2005 04:07 PM
Page generated in 0.10766 seconds (78.57% PHP - 21.43% MySQL) with 11 queries
