| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I have these 3 drivers that have been sitting in the closet. I tested them each for a few hours when I first received them but then have been unused since. 1 for $65 2 for $120 3 for $170 PayPal preferred, no fees. They will ship in their original boxes placed inside of a shipping box. PM for a shipping quote. USPS Priority or UPS only. Please provide full address for International. Thanks. |
#2 |
Specs found:
P10-100MB order no. I-1410297 EUR 170,00 25 cm midrange driver with paper cone power handling (continuous/programme) = 300/600 W resonance frequency fs = 73 Hz impedance R = 6 Ohm sound pressure level SPL = 100 dB (2,83V; 1m) DC resistance Re = 6,5 Ohm force factor BL = 20,9 N/A voice coil inductance L = 0,55 mH effective piston radiating area Sd = 340 cm2 effective mechanical mass incl. air load 35,72 g equivalent volume of compliance Vas = 26,7 l total Q factor Qts = 0,23 (Qms=3,63, Qes=0,25) maximum peak linear excursion vibration xlin = +/- 0,5 mm mounting diameter d = 237 mm overall diameter d = 269 mm mounting depth (not countersunk) t = 118 mm recommended cabinet 1: closed cabinet with 2,1 L volume from 251/158 Hz (-3dB/-8dB) recommended cabinet 2: 4,6 L volume bass reflex cabinet with HP100 reflex tube, 25 cm long. from 155/116 Hz (-3dB/-8dB). Can be found here: Strassacker: Lautsprecher - Boxen - Selbstbau Good luck with sale. I need a PA speaker but looking for something with more low frequency reproduction capability. |
| FS: 8" neoplanar midranges, audio caps, PCBs and more | pkpickard | Swap Meet | 7 | 7th May 2007 04:02 PM |
| New 10" FR from Audio Nirvana. | maxlorenz | Full Range | 0 | 16th July 2006 09:09 PM |
| High efficiency Field coil 10" midranges, Australia | tech.knockout | Swap Meet | 3 | 12th April 2006 07:28 AM |
| Anyone know what drivers in Monitor Audio 10" sub? | The Paulinator | Multi-Way | 0 | 11th July 2003 03:37 AM |
| Page generated in 0.07750 seconds (69.51% PHP - 30.49% MySQL) with 11 queries |
