Lookin fer Brimar ECC85 for my FM3 Lookin fer Brimar ECC85 for my FM3 - diyAudio
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 20th January 2010, 04:36 AM   #1
Bob, W7ETA is offline Bob, W7ETA  United States
Default Lookin fer Brimar ECC85 for my FM3
Have NOS Brimar 6BQ7A for Scott tuners to trade.
Also have a variety of other tubes to trade for other manufacturer ECC85 from Europe.
Best from tucson AZ
Still a novice with electronics.
Old 20th January 2010, 04:41 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Bob,
I have a box of used ECC85, mostly European...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2010, 05:28 AM   #3
What 9 pin tubes do you use Dave?
I finally figured out that I don't have to set up my new table saw in my garage--I live in AZ and have a covered patio!!
I was thinking it had to go in my garage cause the dam pack rats love to eat plastic insulation and plastic hoses that windshield washer fluid goes thru.
It finally occurred to me that the saw I bought has wheels on it! So, I can just wheel it into my garage when I;m done.
Then, I finally realized that I don't have to set it up outside! Into my dinning room it came, door to the patio is there, and out of the box she came!
I can now stand in front of my table saw, read the manual, and wonder what are they trying to say?
I went into the garage where the cut up sheets of 4X8 plywood are. I wanted to check their width. Seems as if I wound up with two 17.25 inch panels and two 12.25 inch panels instead of the right width for my Sachiko build!
Looks like I need to buy more plywood and that I have a lot of plywood to practise on.
Best from tucson
Bob
Old 20th January 2010, 05:53 AM   #4
frugal-phile(tm)
planet10's Avatar
6N1P, 6N6P, 6N30P, 6N23P/6922.6DJ8, EF86, EL84, 12BH7, 6CG7, 12B4
dave
Old 20th January 2010, 07:28 AM   #5
Need your mailing info. I'll mail a pair of 6922s to you that are actually RARE and sound very good--Tungsram Yellow Label 6922; very low distortion, have a tendency to accentuate the beat of music, nice HF extension with out highlighting pops and clicks on vinyl, and have a nice romantic flavor.
Got some Russian 6N23Pi kicking around also--gain matched pairs, nice and quiet.
Come to think of it, I've GOT some nice genuine FAKE JAN Amperex 6922. Be the first kid on your block to own a real pair of FAKE Amperex 6922s. Amaze your friends! Show off at audio gatherings!!!
Everyone has heard about them--but you can show them off! :-)
best from Tucson
Bob
Old 20th January 2010, 07:39 AM   #6
frugal-phile(tm)
planet10's Avatar
Give me a chance to check my stash...
dave
Old 31st January 2010, 12:34 AM   #7
You get a chance to check your stash yet?
Still need your mailing info.
Best from Tucson
Bob
Old 31st January 2010, 02:05 AM   #8
frugal-phile(tm)
planet10's Avatar
Thanx for the poke Bob (was needed)
No Brimar. A Dynaco labeled Mullard. A couple other Mullards.
Lots of other Philips (mostly MiniWatts & Valvos)
About a half dozen Telefunkens.
Some Siemens & Lorentz. A few Japanese.
Let me know which ones you'd be interested and i'll get them tested. 45 total (excluding the ones i got cryoed & am keeping)
dave
Old 31st January 2010, 02:35 AM   #9
Zedguy is offline Zedguy  Canada
Zedguy's Avatar
Bob,
Did you ever get my email?
Old 31st January 2010, 06:21 AM   #10
Hi Dave
I'm using a Mullard old logo ECC85.
On hand I have 6AQ8 Tungsram with a solid U-shaped riser to support the getter and box plates. Identical looking Mullard.
SH labeled Siemens ECC83 with flat ladder plates with dual supports for the getter. Mullard 6BQ7A with small plates and a single riser for the getter. 6AQ8/ECC85 Mullard International made in Japan.
I'm interested in that I don't already have. Singles, orphans are fine to try since the FM3 only uses one for RF gain.
Many thanks
Bob
Lookin fer Brimar ECC85 for my FM3Hide this!Advertise here!
6n3p = ECC85 ??? jamesjung21 Tubes / Valves 21 8th March 2012 09:46 AM
Car audio x-fer in the home 4 to 8 ohm curves masterjr33 Multi-Way 4 2nd July 2006 07:15 AM
Dynaco FM3 220v-120v Ryssen Tubes / Valves 7 8th July 2004 10:20 PM
Help! Dynaco FM3 heater choke billinchile Analogue Source 7 13th April 2004 03:52 PM
ecl86&ecc85 scheme mad_z Tubes / Valves 7 7th January 2003 01:32 AM
Copyright ©1999-2017 diyAudio
