| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hi there
For sale NOS six 2SJ56 Hitachi MOSFETs and six 2SK176 Hitachi MOSFETs. Make an offer. 80V / 40V 800VA Toroidal Power Transformer HiFi / CNC Very good choice for Solid State amp. New 800VA toroidal transformer. It is precisely made for high-end power amp or CNC equipment. It has very low power loss and magnetic leak. Labeled input 115 + 115 Vac (Dual coils), outputs 40Vac x 2 (dual coils) at 10A each, 12Vac at 2A and 18V at 2A. It has CE certified. Mounting hardware is included. The test results are excellent. (note: Please increase 10% of rated power when this transformer use in 60 Hz power source) Open Circuit Test (core loss test): TEST CONDITION: Apply variable voltage to primary coil (115V terminals) from 115-180VAC at 60Hz. No load on secondary coils. 1. Primary V = 120VAC, Primary I = .06A or core loss is 6Watt. 2. Primary V = 140VAC, Primary I = .11A TEST CONDITION: Apply variable voltage to primary coil (115V terminals) from 1-20VAC at 60Hz and short circuit on secondary coils and test the primary voltage and current. The result is 5.5V and 6.8A or 37Watt which is the maximum rated copper loss Dielectric Test: TEST CONDITION: Apply dielectric meter between primary coils and secondary coils; and increase voltage up to 3500VAC. No initiate any spark. Load Test Result: TEST CONDITION: Input 115VAC 60Hz to the primary coil; parallel 2 secondary coils, 5 ohm 250W resistors as dummy load and room temperature at 25 degree C. Temperature rises 5 degree C after an hour test at load test #5. 1. Primary I = 0.06A, Secondary V = 41.2VAC at 0.0A, Power = 0 Watt 2. Primary I = 3.41A, Secondary V = 39.3VAC at 10.3A, Power = 403 Watt 3. Primary I = 6.53A, Secondary V = 37.7VAC at 19.7A, Power = 742 Watt Dimension – 6” Diameter x 3.5” High. Weight – 16 LB net. Wire lead – 12” color-coded. Make an offer. Six Panasonic GAA 10000uF 100V Power Supply capacitors Make an offer. All items are new. Never used. PM me or email to bongolijus@yahoo.co.uk |
| FS - 3 x 800VA 55vac 240v Toroidal Transformers | soundengine355 | Swap Meet | 1 | 5th September 2009 09:58 PM |
| Avel Lindbert 800VA toroidal for sale (60v secondaries) isolation, amp, etc | cowanrg | Swap Meet | 0 | 11th May 2009 12:49 AM |
| Want: Toroidal 800VA 2x30VA | thim | Swap Meet | 3 | 5th April 2009 02:10 AM |
| FS : 35000uf 80V Caps Cornell dub | dhole | Swap Meet | 3 | 31st December 2006 03:33 PM |
| 12,000uf 80V caps FS | Apex Jr | Swap Meet | 4 | 24th January 2003 12:53 AM |
| Page generated in 0.08411 seconds (70.05% PHP - 29.95% MySQL) with 10 queries |
