| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
For Sale
NHT XdW Subwoofer I bought a couple of these from Jack awhile back and don't have room for this one. This is brand new in the box. 325.00 plus shipping Here is some info from Jack's webiste:: "These are a brand new, long throw dual 10" subwoofer with a 500W internal amplifier. Very low distortion. Less than 0.3% at 60Hz at 95dB at 1M. Aluminum cone woofers with 2" diameter voice coils, 12mm Xmax, dual aluminum shorting rings and a cross shaped pole piece. The amplifier has only an XLR input and a +/-10dB volume adjust. The subwoofer has a -3dB point of about 55Hz with a 12dB/octave roll off below that. IT REQUIRES some external EQ to be useable as a subwoofer. You can EQ it to be flat down to 40Hz, 30Hz, 20Hz, whatever you want. This is just a function of the EQ that you have. The upper frequency cutoff is around 250Hz. The NHT product page below has dimensional information. Many of the specifications on the NHT website are only applicable when the XdW is used with the XdA, so they do not apply in this case." Thanks
Guiness
#2 |
bump....
Guiness
#3 |
Hi
What color are they? |
#4 |
Guiness
#5 |
Still for sale? If so, where are you located? Does it include the XLR cable?
Thanks. J |
#6 |
Is this price for a pair or each? I got a pair of S-80s from Jack, and they EQ quite well using a DCX2496 (or similar).
If this is $325/each, then one should know that Jack originally charged $300 plus shipping for these. |
#7 |
Sold
Thanks again
Guiness
#8 |
Jack did charge $300 for them, but Jack is also out of them. They are worth whatever people will pay for them...
J |
| FS: BASH 300W subwoofer plate amps $75ea. NIB | awedio | Swap Meet | 8 | 28th October 2009 05:28 PM |
| Fs: Ddts-100 Nib | jhenderson01075 | Swap Meet | 1 | 28th April 2009 03:12 AM |
| FS: NIB Grado ZF1+ | multi-volti | Swap Meet | 4 | 15th August 2007 06:23 AM |
| Page generated in 0.08600 seconds (74.50% PHP - 25.50% MySQL) with 10 queries |
