Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 2nd November 2009, 08:13 PM   #1
sorenj07's Avatar
Default FS: Custom 6P1P Amplifier
Click the image to open in full size. Click the image to open in full size.
Completely hand-built by myself, mostly my design (with much help from people on this and other forums). Meticulous point to point wiring. Impeccable sound, absolutely zero hum, noise, or buzz. Black background no matter what position the volume knob. 10M45S constant current sources for each tube. Using the highly regarded Z565 output transformers, an Alps Blue Velvet potentiometer, and lab-grade shielded signal cable. Tube complements are a 5V4 rectifier (5AR4 can be used also), military-grade 5965 dual triodes for the input/phase splitter
stage, and military-grade 6P1P-EV tubes. I'll include a spare quad of these.
You get what you pay for. This is probably my 8th amplifier and I have yet to disappoint given the price I charge.
$450 shipped, price negotiable.
Old 3rd November 2009, 05:12 AM   #2
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
I really enjoy seeing your amps. I hope you don't have to negotiate much, $450 seems like a steal! Makes a fella' question whether it is worth it to build their own! Did you build that chassis? That is a mighty looking choke. Is this one choke input (I remember you doing choke input in the past)? Nice work, and good luck with the sale.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 3rd November 2009, 05:42 AM   #3
sorenj07's Avatar
I used a Hammond aluminum project box with custom wood (forget which kind) oiled in 3 coats and sealed with urethane. There is a considerable aluminum bar running horizontally for structural support, to which the 10M45S constant current sources are bolted. The black metal grills which permit ventilation of the power tubes were cut from ATX computer power supplies, sanded, painted, and then bolted.
Once I get this amp back (lending it to a friend), I will post wiring shots
Old 13th December 2009, 10:17 PM   #4
sorenj07's Avatar
Some pics taken by my friend:
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Still available..
Old 17th December 2009, 04:49 AM   #5
MellowTone's Avatar
If you were in Australia, I would almost definitely take that. Alas, shipping is a rather sizable kick in the teeth! Bump for an excellent deal.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 17th December 2009, 07:14 PM   #6
sorenj07's Avatar
Hah thanks. That is very true. I wonder if it would be more than to Hawaii? I once packed up and shipped a SET amp to a client in Honolulu for between $50 and $60, which wasn't too unreasonable all things considered. Needless to say, the amp made it unscathed
Old 4th March 2010, 05:30 PM   #7
sorenj07's Avatar
Bump! Still available.
Old 6th March 2010, 02:18 AM   #8
What is the wattage or this unit? Is it common ground? Where are you located?
Old 7th March 2010, 11:36 PM   #9
sorenj07's Avatar
Hi, the amp is about 12 watts per channel. What do you mean by common ground? It has a grounded 3-prong IEC socket. The signal ground, PSU and chassis all connect to the main ground of this socket. I've never had problems with hum with this amplifier.
Currently I'm in upstate New York.
Old 17th May 2010, 10:32 AM   #10
sorenj07's Avatar
bump..
Sven 6P1P PP Amp TheGimp Tubes / Valves 77 28th March 2010 07:16 PM
My custom sub box audiobahnkid592 Car Audio 4 13th March 2007 04:19 PM
g. pimm's rev3. and rev. 4 -6P1P/5687 ??? sparkle Tubes / Valves 3 20th July 2004 10:56 AM
Custom-colored amplifier components - good idea or no? OddOne Solid State 3 27th February 2003 10:51 PM
Page generated in 0.10777 seconds (79.62% PHP - 20.38% MySQL) with 10 queries
