| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Up for sale is a used and slightly modded Entech "Number Cruncher 203.2" 20-Bit Stereo DAC w/ original power supply.
I made a few changes to the DAC..... OPA2134PA swapped out for LME49860. Panasonic FC in place of the old Nichicon VX main supply caps. 600R output resistors changed to 100R Dale. CS8412 filter mod. I also installed a relay that disconnects and shorts the output when there is no signal locked. I did this because the DAC produces a "hisssssss" sound when it is not locked on a signal which can be very annoying if the amp stays on but the source is turned off. Also included is a Tripath TA2021B based amplifier housed in an old 203.2 case. There is an ALPS 10K log pot installed as a volume control that also has a switch that controls a power relay for the amp board. I will also include a 14V 3.21A "line lump" power supply. The price for the pair is $120 shipped (US only).
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#2 |
Very tempting.
#3 |
Hmm. $100 shipped? Thank you for your consideration.
Niles |
#4 |
I can do $110 shipped.
#5 |
Two of these DACs sold on eb*y recently, one for $76 + shipping and the other for $89 + shipping. A T-Amp in a case will run you around ~$40, and this one even matches the DAC.
#6 |
Sold. I just would like to know a little bit more about the T-AMP, and get a pic or two if possible. Thank you.
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| ESL "matching" Help | VictorG | Planars & Exotics | 3 | 15th August 2003 01:25 PM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.08413 seconds (75.95% PHP - 24.05% MySQL) with 11 queries |
