150 watt digital amp NEW HARRIS - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 11th May 2003, 06:40 PM   #1
Default 150 watt digital amp NEW HARRIS
Never used fully digital amplifier that runs off single supply up to 50VDC, uses H bridge for output. This is a MONO amp, I have a folder with full documentation/schematics/operation theory. Amplifier is Harris prototype using Harris components. I only accept cash,check or money order, no credit card. I live in Pennsylvania USA (zip 17036). Thanks tjshopp@aol.com
Old 11th May 2003, 06:42 PM   #2
Default Forgot price on digital amp
Price is $40.00 plus shipping. Sorry
Old 11th May 2003, 09:53 PM   #3
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
150W is extremely serious for an amp like this. Does it sound any good? I might acquire it as a precursor to my planned Equibit amplifier.
Old 11th May 2003, 10:00 PM   #4
Send a message via AIM to zx3chris
4ohm stable? also is 50vdc required or the max
-chris
Old 12th May 2003, 12:13 AM   #5
Default Digital amp specs
The manual says: 10 - 50 VDC for the output rail and 14 - 18 VDC for the amplifier driver stage, I don't believe the voltages have to be isolated from each other. Its the model HIP4080AEVAL2 150w class D amplifier, The Harris Semiconductor web site should still have info on the amplifier, I believe the cost was $150 US.
I never listened to these amplifiers so I can't comment on the sound.
Old 12th May 2003, 02:46 AM   #6
jwb's Avatar
According to the datasheet, this amp needs two supplies: one for chip power 15-20V, and another bulk power up to 40V, high current. The datasheet also states that it is designed for 4Ω operation, and with an 8Ω load you'll need to change out the magnetcis and capacitors.
Old 12th May 2003, 03:55 PM   #7
sounds like it could be used in a car fairly easily--- i wonder how it woudl work on 12v supplies?? now just need to find a cheap smps
-chris
Old 12th May 2003, 04:15 PM   #8
Is it really a "digital" amp and not just an ordinary class-d PWM amp ?
Charles
Old 12th May 2003, 04:18 PM   #9
jwb's Avatar
It wouldn't work at all on 12V supplies, because it uses linear regulators to supply 12V to the chips. So it needs at least 12V + dropout.
At least, that's how I read the datasheet.
And no, it doesn't not appear to be a real digital amp, but a standard, mono, analog, PWM class-D amp.
Old 28th September 2003, 06:09 PM   #10
Has anyone built one of these yet ?
Found this on the web.
http://wwwlea.upb.de/Aktuelles/Proje...080A_Eval2.pdf
Harris IRF513 (176) Brand new Ardvaark Swap Meet 0 16th December 2008 06:23 PM
Where to find Harris/Fairchild IRF9610?? spzzzzkt Pass Labs 24 19th January 2008 04:33 AM
Harris B886 Powermos Gold_xyz Parts 2 4th April 2007 08:00 PM
Harris HI5-5712-5 / HI5-5901-5 / TRW8314/J Bernhard Digital Source 0 22nd November 2006 05:36 PM
TI Introduces Industry's First Fully Integrated, Single-Chip 100-Watt Digital Audio A mikejz84 Chip Amps 14 9th December 2003 08:37 AM
Copyright 1999-2017 diyAudio
