Hi Guys,
I thought I'd post this here as they might go cheap - keep an eye on them.
I picked these up thinking one day I'd mod them into some sweet amp enclosures - it never happened so they're up for grabs.
The heatsinks are huge and accomodate a 120mm fan (if required)
The exterior is in pretty good nick, but the interior is spotless due to it being a sealed unit. The design allows for racks of PCB's to be mounted inside.
I can add more photos if required.
edit: forgot to add, all aluminium enclosure, the black ends are plastic, I'll have to pull out the measure if anyone's interested in the dimensions /edit
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290336765102
Hi
The enclosure itself is 240wide x 175deep x 450mm long - the black plastic is extra, this does not include the side mounting brackets.
The fins are located at the back, but the unit could be mounted vertically, or used as a plate amp etc...
The fins include - 6 taller fins (57mm) and 7 shorter fins (50mm) all being 450mm tall.
rough calc tells me that equals about 6228cm2 per enclosure just for the fins.
