| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Here are three transformers that I'd rather not move. AFAIK, they came from a Hammond G-100 organ. All three appear to have been manufactured at Midwest Coil. All of my measurements were taken with 120V on the primaries and no load on the secondaries. All of them have cloth leads that are in fine, flexible shape. Buyer pays shipping. $7 each.
#1, This 7lb beaut might work as a filament transformer as it's secondary (center tapped) measures 7.6V unloaded. It really is pretty, with a nice glossy black finish, good fit, and no surface rust. Long, big leads. #2 is a beastly 20lb'er with a 35.5V (again, unloaded) center tapped secondary. The leads are giant. I don't know what sort of voltage you SS guys are typically looking for, but if you need tons of current, this is your boy. It has some rust on the outside of the very nicely stacked lams. Nice long leads. This guy begs for a USPS flat rate box. #3 has two secondaries, one is center tapped and measures 54V (10.7 ohms), the other has no CT and measures 262V (20.1 ohms). It is 9.5lbs and has some surface rust. The leads on this guy are short. pj |
#2 |
#2 is gone, but the others are still up for grabs.
I've also got the PT from an Eico Oscilloscope that I think is 450-0-450 (don't quote me on that). It has a winding for the CRT, but other than that it seem like it could work well for something like a SimpleSE. pj |
#3 |
Another addition:
Stancor PC-8301 415-0-415 (117 primary) Plate transformer (no filament winding) designed for choke input supplies. IIRC, 200 ma for choke input 150 ma for cap input. I bought this guy NOS for $40. It has a mechanical buzz. I tried a couple of things to remedy it, and I think it is there to stay. It runs cool, so it isn't saturating and is perfectly functional. This one would be perfect for a guitar amp or any amp where you don't need it to be dead silent. I'd like to get $10 for it. (buyer pays shipping). |
#4 |
I've also got a couple of little 12.6V transformers. A used Stancor and a brand new Signal. How about a buck for the former and two bucks for the later?
pj |
#5 |
PM Sent
#6 |
The 12V pair is spoken for.
#7 |
I also sold the Stancor. #'s 1 and 3 from above and the Eico are all still available.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
| Source for 2.5VCT 5A filament transformers | dsavitsk | Tubes / Valves | 2 | 15th January 2009 08:39 PM |
| Plate and Filament Transformers | dscrobe | Tubes / Valves | 1 | 21st August 2008 04:57 PM |
| Seperate PSU Transformers? Filament Supplys? | ak_47_boy | Tubes / Valves | 15 | 3rd May 2007 11:33 PM |
| Best price for tube output and power transformers ? | mario2005 | Tubes / Valves | 1 | 31st July 2006 07:12 AM |
| Parmeko Oil Filled Transformers Tube (Valve) Power Amp 110V up to 250V | mozfet | Swap Meet | 5 | 29th October 2002 10:57 AM |
