diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 (http://www.diyaudio.com/forums/swap-meet/145639-fs-vintage-qts-15-woofers-eminence-alpha-15-a.html)
nl 10th June 2009 02:15 PM
FS two pairs of vintage 15" high-Qts woofers, comparable to Eminence Alpha 15. Good for bass support on open-baffle projects. Both stamped frame, alnico magnets, paper cone, accordion surround.
One pair 15" woofers, unlabeled but likely OEM Eminence from late 1960s-1970s.
One pair 15" woofers, unlabeled but likely OEM Jensen from same period.
Each pair $60, plus actual shipping (half the price of new Alpha 15, plus alnico magnets!)
nate@nateandryoko.com
d to the g 10th June 2009 03:30 PM
Have you measured the Q in these?
nl 10th June 2009 10:15 PM
No, but it is probably comparable to Eminence Alpha 15 at Qts 1.26. I used it in a 48" effective width open baffle, and it went down to about 45hz without EQ.
Resources saved on this page: MySQL 18.75%
