| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hello everybody,
If you found somewhere an electronic schematic for device of your dream but you can not route the PCB for it - tell me. I can. Please prepare schematic and Bill Of Material. I will convert your schematic into PCAD, place components, route the PCB. You will have Gerbers output - so then you can make the board by yourself or order it from factory. Doesn't matter digital or analog, one layer or 8 layers. Not expencive. Fast. Professional. I will attach some examples soon. PayPal is acceptable. |
#2 |
An example.
#3 |
Hi
I'm unable to contact you through the forum. Could you please mail me to yfurman at bezeqint dot net? Thanks Yair |
#4 |
Just click on user name, go to user profile,
Contact Grab485: Click here to email Grab485 Anyway, I have send You an e-mail. |
#5 |
How it works.
1. You send me your schematic and BOM (bill of material) as well as desired layers quantity, desired board size, desired price and time. Are you going to produce the PCB by hands or by factory? It is good idea to supply me also with prototype or competitor designs (to estimate its complexity). Would be nice, if every position in the BOM has Farnell and/or DigiKey order code. Or link to the datasheet. The schematic can be in any format, even drawn by hand. 2. I have a look, and report you whether it is possible and my suggestions, advices. 3. After we agreed with technical things and money, we can start the work. 4. I create all the symbols and patterns for components according to their datasheets (I do not trust to "ready to use libraries" anymore). 5. I draw the schematic in my preferred tool (PCAD 2002) 6. You check this new schematic for any mistakes, errors and violations from your own idea. 7. According to your written wishes I do an initial placement.(good time to finally define the board's shape and size) 8. You check the placement, say something, I correct it. 9. Now it is good time to pay me in PayPal. 10. After I receive money, I start routing. Here I might need some additional info from you. For example, manufacturer's suggestions for certain DAC chip routing, etc. Or your own wishes. Or examples from other similar devices. This process is iterative, couple of times I will send you some intermediate pictures from the PCB, you may correct me. (Please, do not expect I will reroute the whole board twenty times just because you "want that capacitor there but not here"). 11. When we agreed that the board is finished, I will produce gerber and drill outputs, you will be able to send them directly to PCB manufacturer. The end. About price. I am not greedy. For example, the board from above example was routed for 120 Euro (156 USD). As additional service, I can produce the PCB. And even solder all the component and check whether it works. Then send to you. Whatever you want. Due to my experience, custom boards rarely work from the first try (mainly because of small schematic mistakes, sometimes routing mistakes etc). |
#6 |
#7 |
Grab, unless your email button is activated, you can't be emailed via your user profile, either. You can do this via your user control panel. Your email address isn't visible (despite the unclear wording of the control panel), but members can then email you either through your profile or through the button.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
TEST
Unfortunately, still without E-Mail button. How? Hurra! It works! Option was: Hide e-mail. And should be Unchecked.... |
| A more direct route | brucegseidner | Multi-Way | 12 | 21st July 2009 05:42 AM |
| Route 66 USA | TomWaits | Everything Else | 16 | 7th June 2007 07:01 PM |
| PG Route 66 problem | Bertje | Car Audio | 8 | 11th February 2007 04:16 AM |
| Page generated in 0.09296 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
