6 channel TA2020 finished amp (setup for 12V)
I still have the 6 channel TA2020 finished amplifier PCB for sale. Purchased from Arjen (forum member). This board was modified so the power supply (110-220V) was removed and now it is setup for 12V. I wanted to use that in my car project but there was a change of plans. Amp was modified and tested by Arjen.
Paid $84 shipped. Make me an offer.
You should be able to wire this amplifier like a regular car amplifier. Remote connection is just 12V that gets turned on/off with ignition. Then you have ground and 6 channels.
You may want to do some research on TA2020 because I have never connected this amp myself. There was a change of plans (cars) and it has been sitting in the box since I got it from Arjen. He modified the board and tested it before shipping.
Duc: I have no idea. Like I said, the mods were done by Arjen (removing 110/220V) and I never run the amp. I am not an expert on electronics but I have purchased another TA2020 (or TA2024) amp from him and run that no problem by supplying line out from my mp3 player. I would think that with this amp it would be the same.
