| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Proud Union Member
Hello all, I have a few toroidal transformers to get rid of.
1- Unmarked removed from a EV/Dynacord P1050 power amp. Includes PSU Board with one bridge and four ROE 4700uF 100v Caps. Secondary 1 is 71-0-71. DC Rails sit at +/- 97v unloaded. Secondary 2 is 23-0-23. Also has I believe a thermistor to monitor temp. Not sure of VA rating but the amp was rated at 550W per channel at 4ohms. Toroid measures 165mm x 70mm with mounts. Includes pads and bolt. PSU board is 240mm Lx 60mm Wx 73mm H. $40 ![]() 1- St. Ives Windings VT3022S removed from an AMEK power supply. Includes euro terminal block for mains voltage selection. Currently wired for 120v. Includes pads but no bolt. Secondary 1 and 2 are 24-0. Secondary 3 is 49-0. (For Phantom) Not sure of the VA rating but outputs were fused at 10A for 20v rails and 2A for 48v. Toroid measures 110mm x 72mm. $20 ![]() 1- Nippon NU1A4b-0130 removed from a Denon CD Cart Machine. Secondaries are being figured out, but there are at least 4. Toroid measures 85mm x 56mm. $10
#2 |
Proud Union Member
#3 |
Proud Union Member
bump
#4 |
Mail sent.
#6 |
Proud Union Member
VA Ratings for the St. Ives Windings Toroid-
24-0 346VA 24-0 353VA 49-0 107VA Calculated at a 10% secondary drop. All are still available. |
#7 |
Proud Union Member
Semi-Annual Bump!
A few more on the way too... |
#8 |
Interesting... PM Sent.
#9 |
Are they all still available? Thanks!
#10 |
Proud Union Member
Everything is still available.
Denon Transformers are: 10.88-0 9.71VA 9.2-0 20.06VA 9.2-0 11.67VA 17.43-0-17.43 34.86VA I have two of these now. |
| Two toroids | BeerCan | Swap Meet | 3 | 9th July 2008 08:51 PM |
| Where to buy HT toroids ? | Jan Dupont | Tubes / Valves | 15 | 23rd March 2008 01:56 PM |
| Toroids FS | sandstorm33 | Swap Meet | 4 | 5th February 2008 04:57 PM |
| toroids | jesserparker | Solid State | 8 | 6th January 2007 06:04 AM |
| WTB: 43-0-43 or 46-0-46 Toroids | K-amps | Swap Meet | 3 | 17th November 2006 08:03 PM |
| Page generated in 0.10193 seconds (77.50% PHP - 22.50% MySQL) with 11 queries |
