| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Pair 18Sound XT1086 waveguides - $100 shipped to the lower 48 states
Pair BMS 4538 compression tweeters - $60 shipped to the lower 48 $150 shipped if you want them all I bought the waveguides new, and they're in excellent condition (about a year old). I got the tweeters used, and they're a little scuffed on the back. XT1086 specs BMS 4538 specs They sound great. The only reason I'm selling them is difficulty in designing the crossover - these are significantly deeper than my 6.5" midrange driver, and I'm having a hard time making the phase line up. If you plan to use them with a larger / deeper mid/woofer, or your crossover design skills are better than mine (which wouldn't take much), I definitely recommend these. My measurements - ignore the absolute levels, these aren't calibrated, and the ripples are most likely due to my makeshift measurement setup. This is with the WG surface-mounted to an 11" wide baffle. The upper set of curves is the tweeter, and they cover roughly 0 - 60 degrees: ![]() Pictures on the baffle: ![]()
#2 |
Do you take paypal?
#3 |
These have been sold.
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| Compression of water (split from Waveguides) | MJL21193 | Everything Else | 424 | 13th September 2008 03:40 PM |
| WTB: 18Sound XT1086 waveguides | Saurav | Swap Meet | 2 | 12th June 2008 03:39 PM |
