Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Sola Transformer 95-130 VAC In 118 VAC Out 60 VA 60 HZ
Old 19th March 2009, 07:59 AM   #1
Scott Novak is offline Scott Novak  United States
Default Sola Transformer 95-130 VAC In 118 VAC Out 60 VA 60 HZ
I have Eight Sola Constant Output Voltage Harmonically Neutralized Ferro Resonant Transformers for sale at $10.00 each.
95 VAC to 130 VAC Input Voltage Range
118 VAC Output Voltage
60 VA (Volt Amps)
60 HZ only
Model # 23-13-060-2 9B
These may be NOS. They don't look like they've been mounted. The transformers have been sitting around for years collecting dust. They aren't in pristine condition but should still be quite serviceable. I have only tested one transformer out of the batch. But I will test each one before shipping.
Possible uses, constant input voltage for Turntables, Electrostatic Speaker bias supplies and whatever else that uses less than 60 VA. I make no claims about sonic effects. But they do regulate the AC voltage well. As these are the harmonically neutralized type, they have a sine wave output.
Local buyers may pickup & save shipping cost. I will accept cash if you are local. But please, no cash through the mail.
Mailing is ACTUAL COST, NO Handling charges!!! Add insurance if desired. Shipping weight is 8 lbs from 55112. I can mail to anywhere in the USA in the Priority Mail flat rate box for $10.35.
I will combine multiple items to reduce shipping cost.
I accept PayPal and can also accept credit card payments through PayPal. I don't accept e-checks. I only accept PayPal from buyers with verified addresses.
sanovak@comcast.net
Old 18th April 2009, 10:24 AM   #2
Default Seven remaining
I still have Seven of these transformers for sale.
sanovak@comcast.net
Sola Transformer 95-130 VAC In 118 VAC Out 60 VA 60 HZHide this!Advertise here!
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
FS: Sola E350E transformer, 350va 24v Destroyer OS Swap Meet 0 4th April 2006 03:03 AM
FS: Sola E350E transformer. 350va 24v Destroyer OS Swap Meet 3 23rd March 2006 10:33 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2017 diyAudio
